Two years brake fluid change.
Mp3 Yourban 300 i.e
Mon Nov 16, 2020 11:56 am quote
Hello guys, just want to show you how my brake fluid looks like after two years.
It has been replaced with Motul DOT4 for both front/rear brake reservoir.. unfortunately I forgot to take pictures to the reservoir with new oil in it but as you can imagine new oil is much clear and you can see very well the bottom of the reservoir.. looks like water compared to the old one.
Most important is the brake efficiency with the new oil, much much better than before.
I still have to change the pedal brake oil because is a bit more time consuming and I think that I have to take of lots of parts to get access to the pedal reservoir and to the bleeding valve on my Yourban..
Location: East Anglia, a dryer region of the UK than Israel
Tue Nov 17, 2020 12:36 am quote
Many owners see this after two years on a new bike. It has lots of chemicals and rubbish in it from the factory. Good job done!
Piaggio MP3 500
Tue Nov 17, 2020 8:49 am quote
I really like the fact that you taped off the reservoir to avoid spills/drips on stuff underneath. Very careful and a great example. That stuff is corrosive!
Mp3 Yourban 300 i.e
Tue Nov 17, 2020 1:21 pm quote
It's a big plastic bag+tape along the edges of the reservoir.
I also washed the whole bike when I finished the job.
It's better to spend 5 minutes on "masking" the area than find damaged painted areas the next day..
2013 MP3 300ie
Thu Nov 19, 2020 12:28 pm quote
Great idea!
I always put some rags around the reservoir - but spilled brake fluid is nearly invisible on those, and might leak through or touch some painted surface when moving the rag - I often end up finding some stains on painted surfaces afterwards.
Will try the plastic bag next time!
Mon Dec 07, 2020 9:36 am quote
Re: Two years brake fluid change.
Another thing you can do for extra protection is polish your bike with a good quality resin polish. I use Autoglym Super resin with another coat of their high gloss top coat over that. That looks great by the way, Gives a true wet look finish! I found brake fluid doesn't seem to affect the paint at all as long as you wipe it off with a wet cloth when you finish bleeding.
Mp3 Yourban 300 i.e
Wed Dec 09, 2020 12:29 pm quote
It's a good idea but my Yourban is green army matt and I don't know if it's possible to use polish on matt paint.. probably not.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   vespa scooterwest scooter west Motorsport Scooters   Cool Ass scooter seat cover
[ Time: 0.2970s ][ Queries: 27 (0.0574s) ][ Debug on ]
