Flat spots on rollers
Tue Nov 17, 2020 6:21 pm quote
So, I did a transmission service on my 2013 BV350, not for mileage (4.5K), but to replace the 7+ y.o. belt. While I was in there, I replaced the rollers/guides, and noticed flat spots on two of them. I've read about flat spots, but not sure what conditions cause them (simple wear?), and am a bit curious why they should show up so early. Seems a good thing I replaced them at any rate.
Something else, related or not, when I bought the scooter a couple of years ago, the seller noted that it always had a somewhat pronounced clatter from the transmission especially at low speeds. Was somewhat hoping the new parts might affect that, but no, still there. Any other BV owners out there have that, or any explanation of what's going on?
2009 MP3 400, 2004 Honda ST1300
Wed Nov 18, 2020 1:44 am quote
A: Normal wear.
B: You may be a candidate for a "Fuzzy washer' mod. Fuzzy Washer Performance Mod Explained
Wed Nov 18, 2020 6:41 am quote
pmatulew wrote:
A: Normal wear.
Thanks. I think the wear part is what I would have expected, just seemed a bit premature.....
The Fuzzy washer sounds interesting..and easy, but to be clear, it's more of an auditory clatter, and not what I'd call a "shudder." Same thing??
Location: East Anglia, a dryer region of the UK than Israel
Wed Nov 18, 2020 7:58 am quote
Flat spots indicate the rollers have jammed in the ramp plate and are not 'rolling'. You therefore may not have been getting the proper gearing as you ride. Regarding the noise, I'm no expert on the BV350 but the one I rode was very noisy from the tranny. It seems that can be normal for some of those bikes. Hope someone else can comment on that for you. Anyhoo....nice job!
Wed Nov 18, 2020 9:00 am quote
Thanks! Funny, I do trust myself not to mess up in a big way (though I still have two mysterious body panel screws waiting to find a home), but there's nothing quite like grabbing firm brake levers after a flush, and a nice test ride after doing work!
With a couple of years of riding it, performance has been seamless, so guessing gearing has been fine (AFAIK). I believe the seller told me he'd asked the dealer about the noise and was told it wasn't abnormal. Not that I'd totally trust the word of a random dealer, but it helps....
2009 LX 150, 2008 GTS 250
Wed Nov 18, 2020 11:10 am quote
Good job with your roller replacement! My LX150 makes the roller rattling noise occasionally when I come to a stop such as at a traffic light. I have discovered a slight blip of the throttle will quiet the noise.
Bill
Wed Nov 18, 2020 11:24 am quote
Bill
I've heard rattling on the LX and GTS, but this is that on steroids. Kind of annoying, but hey, once I'm really moving, I don't care....
Wed Nov 18, 2020 1:44 pm quote
Those are very small flat spots compared to most I've seen. Rollers don't 'roll' anyway, they have to slide a bit on one surface or the other as they are flung out and back.
Sponsor
Granturismo 218
Wed Nov 18, 2020 3:31 pm quote
Adding a washer or two between the outer plate and the bushing as a means of tuning a variator is usually referred to as shimming a variator. You can get kits with a whole lot more shims than you will ever need or want. On the street, it is more popular with the Dr Pulley crowd and GY6 tuners than the people who tune the big bikes. As long as you don't go crazy and put so many shims on that you can't get the nut completely down on the threads, or the belt catches on the way down, you're not going to hurt anything.
.From what I've seen, once rollers start getting flat spots, they only get worse. The pressure on the belt isn't consistent, and when it gets bad enough, they start to get sort of stuck in the groove between the backplate and the drive face, and drag when they come back down. They seem to run hotter, and most of the times when I've seen variators where the bronze bushing has separated from the aluminum on the drive face, or rollers that have melted, most of the rest have big flat spots. If it's time, I would change them. But you can probably get a few thousand miles out of them, and a lot of people would put them back in and have no problems.
LX190, Primavera
Wed Nov 18, 2020 3:41 pm quote
Slider envy?
Sponsor
Granturismo 218
Wed Nov 18, 2020 3:43 pm quote
What's with the new Avatar? It looks like someone stabbed a smurf and is trying to flush it down the toilet.
LX190, Primavera
Wed Nov 18, 2020 4:13 pm quote
Errrr, it was this
Wed Nov 18, 2020 4:26 pm quote
It is impossible for cylindrical or "round" weights to "roll". They might be able to rattle around a bit at idle but not roll.
Thu Nov 19, 2020 10:27 am quote
Rollers actually do a combination of both rolling and sliding, but mostly sliding as you imply.
Thu Nov 19, 2020 5:19 pm quote
Physics won't allow them to roll. I am not sure why they are called rollers and not simply weights.
I suspect it is part of the human experience thing. If one puts then on a bench they might roll away so they are obviously made that way for a reason. So people assume they roll without considering the physics.
Or they are called 'roller" by Dr. Pulley et al to distinguish their product which are designed differently and called sliding rollers, which implies the stock one roll.
All a bit of a misnomer.
2016 GTS 300
Thu Nov 19, 2020 5:33 pm quote
Waspmike, could you explain further why they can't roll, please?
Thu Nov 19, 2020 5:36 pm quote
If they do roll on one side (say against the ramp plate) then they'd be scraping backwards against the variator channels.
They slip and slide, they do not roll.
2016 GTS 300
Thu Nov 19, 2020 5:39 pm quote
Thanks jimc. Just wanted to understand, as when I changed mine at 10,000km (6,000mi) they had bigger flat spots than the OP's rollers.
Thu Nov 19, 2020 5:50 pm quote
Mine would look terrible at even lower mileage! That's when I decided Dr Pulley's would make far more sense - combined with a variator shim washer to protect the oil sump gasket.
With Dr Pulley 'sliding rollers', the flat side slides up and down the flat surfaces of the ramp plate, and the curved side slides against the curved sides on the variator channels. They last a lot longer before going out of shape, which is important for us higher mileage riders.
Thu Nov 19, 2020 8:37 pm quote
Exactly wot he said.
Lx 50 4T, GTS 250, S 150 (Missing in KS), Something Chinese, GT 200 (sold)
Sat Nov 21, 2020 6:49 am quote
It is a roundel on acid. 🙂
Rallies Europe 2016   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.1594s ][ Queries: 27 (0.0333s) ][ Debug on ]
