Setting up and Adjusting 3-way Shocks
1980 P200E , 2005 Stella 177
Fri Nov 20, 2020 8:16 am quote
I've been trying to figure out how to best set up my new shocks that are multi adjustable for compression, dampening and rebound, but haven't really found much online.
I finally found some info in a BGM shock manual that was in German. I used google translate to translate the pages on setting up the shocks and adjusting. This should be enough to apply the same principles to my SIP shocks. Plus there is a little blurb about adjusting shocks in a SIP document I found.
Both documents attached below.
If anyone else has some tips for adjusting these types of shocks, please share!
Adjusting 3 Point Shocks for Vespa.pdf
 Description:
BGM translation
Download
 Filename:  Adjusting 3 Point Shocks for Vespa.pdf
 Filesize:  317.76 KB
SIP Shock setup.pdf
 Description:
SIP explanation
Download
 Filename:  SIP Shock setup.pdf
 Filesize:  4.26 MB
Fri Nov 20, 2020 8:32 am quote
I want to make sure I understand where the correct settings are on specifically my SIP shocks. So i've attached photos pointing out what I believe each adjustment is. Let me know if I've got these wrong.
Spring Preload
Compression Damping
Rebound Damping
Fri Nov 20, 2020 9:21 am quote
Love this post - though I am too lazy to read and understand all of it.
Hopefully someone will boil it down a bit.
At least now I know which one is compression and which one is return!
Thanks!
2007 Stella 150
Fri Nov 20, 2020 9:57 am quote
The only one I know you have correct is spring preload. the rest is mystery, I don't have them fancy shocks like you big city folks.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   vespa scooterwest scooter west Motorsport Scooters   Cool Ass scooter seat cover
[ Time: 0.2123s ][ Queries: 27 (0.0485s) ][ Debug on ]
