Headlamps not working
Vespa LX 125 2011
Sun Nov 29, 2020 12:24 pm quote
I started frying headlamps with frequency so ordered a new reg/rec
On fitting I still have no headlamp although the day light is on..
Figured to replace fuses and relays at the same time as these items are of an unknown age
Any suggestions appreciated
Sun Nov 29, 2020 12:41 pm quote
There's a 15A fuse and a relay in the current path for the headlight. The fuse has probably died, though it's also possible the relay (or connection to it) is causing trouble.
Vespa LX 125 2011
Sun Nov 29, 2020 2:22 pm quote
JimC...
So that fuse and relay are located beneath the saddle, helmet store yes?
Sun Nov 29, 2020 5:11 pm quote
The fuse is by the battery, together with the main fuse. Both are 15A.
I'm not near an LX at the moment, so can't give you the location of the relay, as it's ages since I rootled about inside an LX!
Team Scooter Trash for Petfinder Foundation   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.2089s ][ Queries: 26 (0.0591s) ][ Debug on ]
