Schoolboy error on installing new brake pads?
150 Sprint Veloce,Vespa GTS 300
Fri Nov 20, 2020 12:27 pm quote
I think I have made an error somehow installing a new set of rear brake pads on my GTS
The pads came today, and while the rear wheel and exhaust were off, I took the chance to work on them.
Firstly I bought these brake pads, because I was happy when I bought these for the front brakes a few years ago, on an older GTS.
https://www.ebay.co.uk/itm/Vespa-GTS-Rear-Brake-Pads-EBC-SFA321-GTS125-250-300GTV/183896119346?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
However, on fitting them, I noticed that the brake "pistons" were sticking in, so making fitting the fresh brake pads difficult. As the "pistons" were forcing the pads to close in, it was impossible to put the whole assembly back onto the disc!
So, I took the new pads back out, drained the brake fluid out of the brake fluid reservoir at the headset, and opened the bleed valve on the brake assembly to let some fluid out. I then found short piece of wood that allowed me to close the "pistons" and get some clearance so I could put the assembly back onto the disc.
I tightened things up, put the wheel and exhaust back on and noticed that there wasn't any resistance on the brake lever, it was as if there wasn't any fluid back there, and therefore the brake doesn't "brake" anymore!!
Where did I go wrong? and how can I get things sorted out now??
Sheesh, I suppose it means I've got to take off the wheel and exhaust off again!!
Graham
S150, Beo 500ie
Fri Nov 20, 2020 12:43 pm quote
Um....are you aware that you need to bleed the brakes after removing fluid and introducing air into the system?
Fri Nov 20, 2020 1:26 pm quote
Bleed the rear brake. This can be quite a tiresome task on the GTS if fluid has been removed already, as there are places where air pockets like to stick. Best to reverse bleed.
Next time, before removing the old pads, press the pistons back with a screwdriver or other suitable tool. They should stay where you leave them as long as you don't touch the brake lever. There's no need to remove any fluid.
Sat Nov 21, 2020 1:46 am quote
hmmm reverse bleed, I'd never heard of that! How do you go about a reverse bleed Jim?
Graham
BV 350
Sat Nov 21, 2020 2:20 am quote
Uh-oh
Reverse bleeding forces fluid through the caliper bleeder screw, through the system, back into the master-cylinder reservoir using a large syringe or other device.
Was forced into a similar scenario when my BV350 brakes got air in them. Took me a couple of days to find success, and a quart and a half of fluid. Not doing that again if I can help it.
Or you can make an adaptor for your master cylinder, buy one of the pressure-bleeding sytems, and force fluid through from the master cylinder.
Idea, either way, is to get enough fluid flow to carry the air out of the system, not always possible using the classic bleeding process.
FYI, the proper process when replacing pads is to just press the pistons back in, while keeping an eye on the MC reservoir to assure it does not overflow as fluid is forced back into it. If someone added fluid as the pads wore to maintain fluid level, some may need to be removed. That way, little if any chance of getting air in the system.
If you do not periodically replace your brake fluid, also a good time, after the new pads are in, to run fresh fluid through the system. I siphon out as much old fluid as I can from the MC, fill with fresh fluid, and bleed, using the normal method, until clear, clean fluid comes out the bleeder screw.
Missouri Loves Company Rally   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1380s ][ Queries: 25 (0.0470s) ][ Debug on ]
