Malossi O2 Lambda Emulator on GTS HPE
Vespa Supertech 2019 (EURO3/APAC)
Fri Nov 20, 2020 6:14 pm quote
some observations ...
I had it installed for about 2 months and have temporarily uninstalled for the last several days (will stick it back in soonish).
with installed (not high speed / freeway):
1. lower mileage. 30-32 km/l -> 27-28 km/l This is to be expected
2. more clutch slippage / shudder at lower revs (10-15 km/h in carparks etc)
3. more 'go' when taking off at the lights (with ASR disabled). WIN!
I'm pondering the clutch slippage still. Was able to easily adjust my style. May install a malossi or polini clutch ...
Notes:
* It's a supertech so I can check things like mileage by using the phone app that records the telemetry
* using an Arrow after market exhaust
Blue GTS300 Super 2015, White GTS300 Super 2018
Fri Nov 20, 2020 7:25 pm quote
Lower mileage might be because of the way you take off with the Lambda Emulator installed.
Dr.Pulley HIT clutch is good for locking the clutch and preventing slipping, but this can cause jerks when you open the throttle at low speed. It is expensive. But I don't know anything about tuning the HPE transmission, having only worked on earlier models.
Fri Nov 20, 2020 7:31 pm quote
doubt this as this should be a minor effect when doing enough kms
2011 LX150ie w/ 190cc Malossi Kit
Mon Feb 08, 2021 10:53 pm quote
does anyone know how the emulator works?
GTS 300 SS BB
Mon Feb 08, 2021 11:15 pm quote
I don't know this emulator of yours, but generally speaking, the idea of omitting the Lambda sensor, would be to allow the engine to run richer.
Not sure if the Vespa also has a temperature air sensor on the inlet, but that normally works in conjunction with the lambda sensor.. (not all engines have it).
So, I'm presuming that, that is what your emulator is doing. Is telling the Vespa ECU that either the fuel mix is lean and/or that the air temperature is low..
When an engine run too rich, that is when you get the shudder at very low revs..
But the soon it picks up a bit of rev the acceleration should be much, much better than with the OEM Lambda
Obviously you are getting a fraction lower mileage because you are putting more fuel into the combustion chamber when accelerating..
It is a bit of a compromise, but at least you know it is working as intended..
Mon Feb 08, 2021 11:49 pm quote
The malossi emulator intercepts the o2 lambda sensor from the exhaust only (no air temp)
GTS 300 SS BB
Tue Feb 09, 2021 12:08 am quote
That's good. It makes it a lot easier for the ECU to be trick into thinking that the fuel mixture is leaner that what it is..
Sponsor
Granturismo 218
Wed Feb 10, 2021 12:20 pm quote
It richens the air/fuel mixture to about 6K RPMs. That's when the Piaggio ECU stops taking in information from the O2 sensor.
Land of 10,000 Scoots Rally   vespa scooterwest scooter west Motorsport Scooters   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1571s ][ Queries: 25 (0.0387s) ][ Debug on ]
