Fuel Light Blinks - 2017 BV 350
BV 350
Sat Nov 21, 2020 12:15 pm quote
Hi, I own a 2017 BV 350 1,500 miles on the odometer. All of a sudden the fuel light blinks and the fuel needle registers as empty even though I know that there is a fuel tank of gas. I was wondering if anyone else had this problem and what the remedy was. Thank you
Sat Nov 21, 2020 12:41 pm quote
The float on the fuel gauge has got stuck, OR the connections to it have gone open circuit.
Wiring diagram here:
https://manuals.wotmeworry.org.uk/Beverley/BV350/
BV 350
Sat Nov 21, 2020 12:47 pm quote
Fuel Light Blinks - BV 350
Thank you for your response. How do I go about unsticking the float on the fuel gauge and checking to see if the connecors have gone open circuit.
Sat Nov 21, 2020 5:34 pm quote
Checking the connectors is the easy one - just check the resistance between pin 12 of the speedo unit and ground. If that's infinite then either a wire has chafed through (follow the harness) or the connection on the fuel level switch is bad. To check the latter you'll need to drop the tank, and if you're doing that you can access the fuel level sender itself to check it.
If that resistance is not infinite (not open circuit) then the fuel level sender and its wires are OK, and the fault must lie within the speedo unit.
BV 350
Sun Nov 22, 2020 11:30 am quote
Fuel Light Blinks
Hi, When I turn the ignition on the fuel neele moves all the way to the right (Full) but then goes all the way to the left (empty) side. How do I access the 12 pin speedo unit. What do I have to disassemble to get to the speedo unit. Thank you
Sun Nov 22, 2020 2:11 pm quote
I don't know, I do not own a BV350, and haven't yet worked on one. The workshop manual may well give you some hints.
BV 350
Mon Nov 23, 2020 1:15 pm quote
Fuel light blinks BV 350
Hi, Thank you for your suggestions, I will try to get my hands on a shop manual.
Anyone else who has any thoughts regarding my problem I welcome any of your suggestions.
Rallies Europe 2016   Vespa Wasp Pin Badges   Cool Ass scooter seat cover
[ Time: 0.2838s ][ Queries: 27 (0.0794s) ][ Debug on ]
