2019 MP3 500 Sport
Sun Nov 22, 2020 11:54 am
...since I have no other references and never had ridden one before, is the knocking sound and vibration at very very low reps normal? I assume so since it's a big one cylinder with auto clutch, just asking.
2015 MP3 500 ie Business
Mon Nov 23, 2020 5:07 am
Describe more in detail and vehicle service history, miles on the clock, etc. Does the noise go away when the revs climb? Does the noise only occur at idle and take off, etc, etc, etc?
Might be a simple case of needing slightly lighter or worn vario weights.
2019 MP3 500 Sport
Mon Nov 23, 2020 7:55 am
the bike is a 2019 with 1,200 miles.
it's only and exclusively at very low reps during takeoff from a stop, you know, the first 2 seconds or so after applying throttle...
Mon Nov 23, 2020 9:27 am
Sounds like the typical bucking syndrome that the 500 is known for.
Either put in a complete of lighter set of rollers OR do what I did. Remove 4 of the black stock 25gram rollers and sub in 4 light blue 21gram stock Piaggio rollers from a older 500. Be sure to keep a staggered pattered in the proper orientation (21-25-21-25-21-25-21-2) to keep things balanced.
Makes night and day difference and cheapest mod
