Smog system removal california movin to colorado |
Post Reply Forum -> General Discussion |
Author | Message |
![]() So im new and im wonderig what california smog systems are not necessary and would add performance
![]() ![]() GTS 300ABS, Buddy 125, Buddy Kick 125
Posts: 11609 Location: Oregon City, OR |
![]() What "California smog systems" do you think a 20 year old ET4 has? Most cleaner burning modifications in scooters are designed into the engine and electronic ignition system. (actually, 14 other states including Colorado have adopted California vehicle emission standards in any event)
![]() ![]() In garage: Yamaha Tricity 155 Urban 2019 - MV Agusta 125 RS 1956
Posts: 5003 Location: Latina (Italy) |
![]() The only way to increase performance is to increase the displacement ... maybe a small kit?
Ask Motovista. |
![]() Attila wrote: The only way to increase performance is to increase the displacement ... ![]()
Positive
![]() Sledge wrote: Attila wrote: The only way to increase performance is to increase the displacement ... ![]() When I weighed 20 kg. less my scooter had more speed and now if I have to go to the mountains I have to drink castor oil for two days first. ![]() |
![]() ![]() 2010 S50 Modified "Punkin"; 2003 ET4 Malossi 187 "ISO"
Posts: 664 Location: Deepinnaharta, Texas |
![]() Greetings:
Removal of the evaporative canister from my 2003 ET4 improved the idle smoothness tremendously, and cleaned up the transition to the part-throttle operation as well. I don't think the system design was the problem in itself, but the 17 year-old hoses appeared to have developed some porosity, thus admitting air and making it nearly impossible to set the idle mixture correctly. You could consider replacing instead of deleting said hoses and clamps at great expense, if the parts are still available. I am nearly certain that the city of Denver still does smog checks on cars. Not sure about scooters moving in from out of state. The Denver Smog Test site doesn't mention them in a cursory viewing. I documented my own Evap. Deletion process here in a thread, but there are far better tutorials online everywhere. This is one place where a Robot (ScooterWest) video likely does not exist, because a large retailer doesn't want to be associated with an "anti-environmental" and possibly illegal modification. |
![]() 2020 Vespa GTS Touring 300
Posts: 174 Location: Northern California |
![]() Well anyone who spent time in Asia might be wondering more how to fix the old system so it worked properly rather than ripping it out.
Air Pollution in Asia: Real-time Air Quality Index Visual Map https://aqicn.org/map/asia/ |
![]() No smog test for scooters in Colorado. Get rid of it. Replace your fuel and vacuum lines. Do the fuel filter and bypass the SAS while you are in there. Your scooter will thank you.
![]() Abner_Bjorn wrote: No smog test for scooters in Colorado. |
![]() ![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 39324 Location: Pleasant Hill, CA |
![]() Dooglas wrote: Abner_Bjorn wrote: No smog test for scooters in Colorado. * It's only crap on motorcycles, particularly Piaggio ones. |
![]() jimc wrote: They don't at the moment, true, but it's the CA mandated evap crap* that can be removed. |
![]() ![]() 63 GS / 78 P200 / ET4x2 / ET2 / GT60x2 /16 Prima Anniversary/ 03 a Ruckus / 2021 Sean Wotherspoon x2 / 2013 946
Posts: 6451 Location: Thousand Oaks |
![]() Platinumet4 wrote: So im new and im wonderig what california smog systems are not necessary and would add performance SDG
Positive
![]() ![]() S150, Cosa LX200, DL1000V
Posts: 510 Location: Sunny South West UK |
![]() I look forward to the day when altering vehicles to make them more polluting than when they were manufactured is more widely seen as socially unacceptable... We've all got to breathe the same air after all.
Neutral
![]() ![]() Weird 80's Vespas & Cool Vintage Lambrettas
Posts: 8481 Location: The state of insanity, SoCal |
![]() *yawns loudly*
this topic bores me, charlie murphy. you want some pancakes? anyway... just pull the hose off the carb and call it done. you're not going to gain any performance. to do so, you'll need to upgrade either the engine or the transmission. however, it may start a little easier and run a little better. i'd also recommend a #38 idle jet at the same time. -g |
[ Time: 0.1512s ][ Queries: 25 (0.0341s) ][ Debug on ] |
