Tilt lock stuck + alarm ==> solved!
MP3 500
Tue Dec 08, 2020 12:48 am quote
My tilt lock was stuck, its alarm beeping all the time, and the scooter won't ride because the throttle doesn't release.
Eventually, my mechanic directed me over the phone how to resolve this.
There's a small electric motor above the right front wheel. This motor is a part of the tilt-lock mechanism. It has a small black rubber cap that you need to remove, revealing a little valve you can turn with a slim flat-head screwdriver.
Just turn that valve a little to the left and to the right, turn the scooter off and on again, and try to release the tilt-lock again (you can put the scooter on the rear stand so that it doesn't fall when the tilt-lock releases).
If it doesn't release with your weight on the seat, try tapping the release button twice fast.
This worked for me just now, and now it's working fine.
1. Front view
2. Closer look
3. Black rubber cap
4. Valve (you can see the little place for the screwdriver to turn it)
MP3
Sat Dec 12, 2020 7:53 pm quote
Fixed my issue amazing outcome , advice.
Did exactly as the post said. It freed the wiper motor and hydraulic pump
Most appreciated
Was a throw the bike away mode as not economical to fix.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.1900s ][ Queries: 27 (0.0328s) ][ Debug on ]
