Top Case for gts
Gts 300 notte
Tue Jan 05, 2021 8:23 am quote
Hey guys, so i am interested in getting a top case with the included backrest. i dont have any mods on the vespa currently, just have the standard factory seat bar. So i just want to make sure, in order to install the top case i need to have a different seat bar, one that the top case sits on, correct? so i have to get a rack as well as the top case..... just making sure. thank you!
Tue Jan 05, 2021 9:00 am quote
Yes, you do need a rear rack to mount the Vespa topcase. There are two different rear racks for the GTS. One is composed of two parts and flips up when not in use, the other is just a plain rack which remains in the down position. The plain rack is usually used to support an OEM topcase.
GTS 300
Tue Jan 05, 2021 4:15 pm quote
Install of the rack and case is pretty easy. Robot has a good video showing how to do it with both the folding and fixed (what I have) rack.
2018 Vespa GTS 300 Touring
Tue Jan 05, 2021 4:18 pm quote
OEM topcase
I recently bought an OEM topcase and it worked with the standard OEM fold down rack on my 2018 GTS 300 Touring.
GTS 300
Tue Jan 05, 2021 4:22 pm quote
Here is a picture of my GTS with the fixed rack while I was waiting for the case to come into stock. The top case slides onto two metal tongues on the rack and a screw through the bottom of the case holds it in place to the rack. Note you will also need a different screw cover for the spot where the lower arm of the rack attaches to the frame.
Tue Jan 05, 2021 6:38 pm quote
Do yourself a favor, get a GIVI. I have the V47. They arenít color coordinated but built better & larger. Additionally I installed an AdMore light kit in it and mounted a rack on top.
SilverWing 600-- 4nprevious Vespa
Wed Jan 06, 2021 12:58 pm quote
Agree on Givi---my e-46 box (made 1998) has over 500,000 miles on various bikes/scooters. They have backrests that bolt to box. Their racks are foolproof.
2020 GTS 300 HPE
Sun Jan 10, 2021 8:00 am quote
Another fan of the Givi top case. I have a 37L that was on the black 2009 GTS I had, and switched it over to the 2020 GTS HPE I bought in October. I was able to find a colored insert for it that matches the Vespa blue - it pulls it all together (in my eye)...
I like the look and storage better than the Vespa OEM top case. If you want, a passenger pad can be fitted; no need for me, since my wife rides her own scoot. I added the fixed rack (had the flip down one on the 2009, but didn't see any use for that since the top case is always on there. Also, with the Givi, it is one button push to remove the top case if you need just the flat rack for strapping something on there.
GTS300HPE PX150 BMW1200R
Sun Jan 10, 2021 3:38 pm quote
I went for a refurbished 2010 top case.
Because the Australian import is so useless, I had to find my own anyway, and took the opportunity to use one tha I could find the Admore lighting kit to
Step 1: Topcase repainted to match body (colour not available from importer)
Step 2: Seat and backpad re-covered to match, using a black / yellow colour combination from a 2020 seat.
Step 3: Fit Admore LED light kit
Mon Jan 11, 2021 12:24 pm quote
You can go with Givi or Viking, they both have top trunk cases and those do have plenty of room in them. Check out all the options and choose wisely.
2013 Vespa GTS 300, 2007 Vespa LX150 (sold)
Mon Jan 11, 2021 5:21 pm quote
I have the Shad SH40: https://www.shadusa.com/collections/sh40-cargo. There is an optional backrest for it.
I chose a Shad over a Givi because Shad does not require you to lock it. That is, I can open/close the case without having to use the key (I'm lazy). When I need to lock it I use the key.
Mon Jan 11, 2021 6:00 pm quote
I used X9 topcases on our VCdM Vespas - this was in Cinque Terre, Italy:
GTS 300
Mon Jan 11, 2021 6:55 pm quote
Those look nice. Never heard of X9 but will look them up.
Wed Jan 13, 2021 5:29 am quote
Wow... any idea what ship that is?
2010 ThunderFly 190, 2008 250 GTS
Wed Jan 13, 2021 7:24 am quote
If you get a Givi E370 or V46, Admore Lighting makes a kit to give you tail, brake and turn signals. I installed in each of these that I have and is a big visibility improvement.
Pic of my V46 setup on the GTS from behind, brake lights on.
Team Scooter Trash for Petfinder Foundation   DoubleGood Vespa T-Shirts   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.3066s ][ Queries: 27 (0.0791s) ][ Debug on ]
