et4 50
Fri Jan 08, 2021 8:56 am
Hello I’m riding a gts hpe 300, with a scorpion exhaust love it to bits but was toying with the idea of the malossi force maser 3 to get a bit more out of her, has anyone put one on a hpe or could give me any advice, it looks like a good option without any major mechanical work.
Blue GTS300 Super 2015, White GTS300 Super 2018
Joined: 01 Nov 2005 Posts: 2792 Location: Sydney, Australia
Fri Jan 08, 2021 1:17 pm
From what Malossi have published it will extent the rev limiter and eliminate the speed limiter, but there is absolutely no information about performance. I guess that as usual they want us to do the beta testing for them.
I've tried the ForceMaster 2 on both my GTS250 and GTS300, and couldn't detect any performance improvement. So I've just stuck with the Lambda Emulator, which did make a noticeable difference.
Joined: 11 Jun 2011 Posts: 3220 Location: East Anglia, a dryer region of the UK than Israel
Sat Jan 09, 2021 2:44 am
It's a pointless waste of money if you haven't modified the bike with an engine kit. It won't actually do much so you will notice, and may not do anything at all except empty your pocket. Using the Forcemaster 2 on euro3/4 bikes (as opposed to the 3) with just an exhaust job doesn't do anything either as Mike says. Although I don't know anyone that has done this on an HPE. You could be the test guy, but don't hold your breath on getting any sort of good result.
Sat Jan 09, 2021 1:35 pm
The HPE has a fair bit more performance than the earlier models, which means it is more highly tuned. So there is much less scope for performance mods to achieve anything.
The only things I've heard of for the HPE are the Kubler tone disc and the Polini large bore cylinder. I know nothing about what has changed in the HPE transmission, except that it uses a shorter belt.
But just about the first mod I wold make to any GTS is to replace that front shock with a Bitubo or BGM or something.
Vespa Supertech 2019 (EURO3/APAC)
Sat Jan 09, 2021 2:44 pm
I have the Lambda emulator on my HPE and it did seem to give it a little extra kick off the line. (hopefully not perception?)
the Forcemaster also includes Lambda emulator and also increased rev limit so theoretically could give some perf improves over stock.
But I do suspect that with the design of the forcemaster with it's adjustment dials and the ability to upload new user maps into it that it would really require time on a dyno and lots of skill to set it up properly ...
Sponsor
Granturismo 218
Sat Jan 09, 2021 4:16 pm
Anybody who works with power commanders or similar devices knows what they do, how to get them to do it, and should be able to help tune it, so you want to go to a motorcycle speed shop. Anybody who doesn't know what they do or how to tune them won't notice as much of a difference. If you find someone who knows what they are doing, you can get everything you mentioned, and the bike will be smoother and quicker as it accelerates. You can get rid of the dead spot that European bikes have about 4K rpms.
To get the most out of the forcemaster, you should go with lighter weights and the longer belt, either Malossi or Piaggio.
