Hi all! Just bought a 2008 GT250ie with 25k miles on it. No rust, and appears to be in excellent mechanical condition, but the service done on it is unknown.
What should I do as far as mechanical maintenance? So far I’m going to:
- replace the belt and overhaul the variator and clutch, using this kit https://www.scooterwest.com/deluxe-belt-variator-clutch-overhaul-kit-vespa-gts-250.html
- make sure the clutch pads are still good, and replace if needed.
- change the oil and clean the air filter.
- replace spark plug
- check coolant and hub oil levels
Anything else I should do while it’s cracked open, assuming nothing seems off? Like should I crack open the engine and adjust the valves if it seems fine, or is that overkill? Something else maybe I should do?
Thank you!
