LX50, LX150
Joined: 28 Oct 2020 Posts: 17 Location: Bradenton Florida
Fri Jan 08, 2021 9:58 pm
I recently got a lead on a low mileage 2012 Piaggio Fly 50 4T4V with no title. I was thinking about buying it and swapping the motor and drivetrain into my wife's 2006 LX50 4T2V. I know I would have to include the module and harness. I know all the Malossi parts in the drivetrain I installed in the LX50 will transfer to the fly drivetrain but will there be any issues with gauges or lights? I know the Piaggio line and Vespa line share the same drivetrain but I'm not sure about the electronics.
Joined: 22 Nov 2016 Posts: 580 Location: Winston-Salem, NC
Sat Jan 09, 2021 3:25 pm
It would need the wiring harness because they are very different beasts. The 4v is a much smatter engine. The 4v engine also has the heat sensor and a sensor that gets a hose off the carb, don't forget those.
LX50, LX150
Sat Jan 09, 2021 8:49 pm
I figured I would have to use the wiring harness. Wanted to see if anyone has swapped out a 4t2v for a 4t4v. I'm just concerned if I will have any issues with the connection of lights, switches etc. and if it would be worth it as it's going to require me completely disassembling the LX
