P200 headset indicators - weird issue.
1981 P200E / 1979 P200E / 1974 Rally 200
Sun Jan 10, 2021 12:42 am quote
I installed a new wiring harness, and having this strange issue. with the two headset indicator lights.
Turn signal indicator: It faintly glows when it's not active. But when the turn signals are on, it blinks in/out as it should.
High beam indicator: Stays on in both positions.
Has anyone experienced this?
2007 Stella 225
Sun Jan 10, 2021 3:48 am quote
Re: P200 headset indicators - weird issue.
On the wiring diagrams for a P200 that I've looked at the high beam indicator and high beam headlight bulb filament get power from the same wire at the headlight. This power comes directly from the switch. Are you sure the high beam is off?
Here is a schematic from scooter, if you don't have one.
https://www.scooterhelp.com/electrics/pages/VSX1T.p200.html
The turn signal faint bulb is interesting also. According to the diagram linked above, the bulb is connected to "P" on the indicator flasher relay. What happens when you disconnect it from the relay? Hopefully it goes out, if it does I would try a new Indicator relay. I would put in a digital indicator relay if you can get one, for that particular scooter. I put one in my Stella and the lights were brighter, it comes down to.the old style uses a small heater setup to chase the flashing and uses part of the voltage that would be going to the lights. A new digital relay doesn't do that, it has a built in timer.
Also.did you happen to install led bulbs by any chance?
If it doesn't go out you'll need to figure out what is wrong with the wiring harness.
VSX1T.USA.after.pdf
 Description:
Download
 Filename:  VSX1T.USA.after.pdf
 Filesize:  42.05 KB
Sun Jan 10, 2021 12:24 pm quote
It's so strange!
I didn't install LEDs. Looks like the turn indicator is the flasher unit. The quality of reproduction parts, or maybe the wiring of the vespa required a specific flasher.
The first one I ordered didn't power the dash light at all. The second one operated like this. I'm guessing the way the switch works, it has some amount of ambient current that is enough to make the tiny light glow.
The headlight is really confusing. The switch works fine on the light. Only one beam in each position, and the indicator is connected to the switch.
Seems like maybe bc they share a ground attached to the speedo, there could be something with that?
Team Scooter Trash for Petfinder Foundation   vespa scooterwest scooter west Motorsport Scooters   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1467s ][ Queries: 27 (0.0237s) ][ Debug on ]
