Vespa GTS 300 Super
Sun Jan 10, 2021 5:18 am
Hi all, what exactly do i need to do to fit 13" MP3 wheel to my Gts 300??
Gilera Fuoco 500ie
Joined: 11 Oct 2009 Posts: 4237 Location: Netherlands Olst
Sun Jan 10, 2021 11:49 am
only the wheels and tyres
Joined: 11 Jun 2011 Posts: 3158 Location: East Anglia, a dryer region of the UK than Israel
Tue Jan 12, 2021 3:34 am
What year is your GTS300? Does it have abs/asr? If it doesn't have abs/asr it's an easier job. But you might have some issues if it does.
Gilera Fuoco 500ie
Tue Jan 12, 2021 5:36 am
no get the ABS wheels with rings if it got abs
2015 MP3 500 ie Business
Tue Jan 12, 2021 9:01 am
^This, and don't forget to recalibrate the ASR after you've put on the new rims and whenever new tires are installed.
The calibration procedure can be found in your owner's manual.
Tue Jan 12, 2021 11:07 am
The 13" rim will fit on the front of the Vespa GT/GTS/GTV You can also fit the rear with some modification. Please note you will have to upgrade to 13" tires with a lower profile such as a 130/60x13 and must use the hardware kit.
You can read the owner's manual and need to do some modifications.
MP3 250 & T Max
Joined: 27 Feb 2014 Posts: 63 Location: Auckland,New Zealand
Sat Jan 16, 2021 4:00 pm
Is converting to 13' rims with lower profile tyres a common mod with Vespa riders? I fitted My MP3 250 with a 14" rim on the rear and wouldn't go back to 12"
What overall benefits do you find on the Vespa to make the conversion worthwhile?
