Bought this from Mercato. It’s perfectly flat
This is the other Vape fan wheel tool SIP sells
Not sure how the blades match up
Mounting holes dont line up either
Doesn’t line up with the actual flywheel either.
Vape fan holding tool |
Post Reply Forum -> Not-So-Modern |
Author | Message |
![]() ![]() 73 & 74 Rally, 76 ET3, 80 P200, 06 PX150, 61 Ser 2, 65 Silver Special, 86 & 96 Elite 80s, 2015 HD Road Glide Special, 2011 Ural Tourist
Posts: 3843 Location: Oceanside, CA |
![]() So I just got the vape kit today and I sprung for the optional fan holding tool. I forgot the bracket (whoops!) but I’m trying to figure out how to use this holding tool. Is it late? Am I dense? Did I get the wrong part? Are the Germans drunk? This tool is perfectly flat and doesnt work with the fan blades on either end of the tool, multiple holes dont line up, etc. Can anyone tell me what I’m missing?
![]() Bought this from Mercato. It’s perfectly flat ![]() This is the other Vape fan wheel tool SIP sells ![]() Not sure how the blades match up ![]() Mounting holes dont line up either ![]() Doesn’t line up with the actual flywheel either. |
![]() ![]() 2007 Stella 225
Posts: 1404 Location: Rochester, Minnesota |
![]() Not sure what your trying to use it on, but SIP does list three tools for three different model scooter motors.
![]() ![]() 76 Sprint V, 63 GL, 62 VBB, 05 Stella
Posts: 2974 Location: Nashville |
![]() If it's perfectly flat, is it designed for the VAPE flywheel without the fan installed?
![]() Trying to use it on a VBB. Regardless of the model, shouldn’t things match in the kit?
I’ve tried it on just the flywheel. Look at the last picture. Only 1 out of 4 holes can work at the center of the tool. [/url] |
![]() MJRally wrote: Trying to use it on a VBB. Regardless of the model, shouldn’t things match in the kit? I’ve tried it on just the flywheel. Look at the last picture. Only 1 out of 4 holes can work at the center of the tool. [/url] https://www.sip-scootershop.com/en/product/holding-tool-sip-vape-fan-wheel_20095400?q=holding%20tool%20vape |
![]() Christopher_55934 wrote: MJRally wrote: Trying to use it on a VBB. Regardless of the model, shouldn’t things match in the kit? I’ve tried it on just the flywheel. Look at the last picture. Only 1 out of 4 holes can work at the center of the tool. [/url] https://www.sip-scootershop.com/en/product/holding-tool-sip-vape-fan-wheel_20095400?q=holding%20tool%20vape I said regardless of the model, why couldn’t you have a universal tool? I understand lambretta flywheels are smaller but for a Vespa, what factors do you have to deal with that you need to have 3 variations of a tool? |
![]() ![]() 1979 P150X, 1983 P200E, 1988 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Posts: 2143 Location: Veria, Greece |
![]() MJRally wrote: what factors do you have to deal with that you need to have 3 variations of a tool? |
bodgemaster
![]() ![]() 63 GL, 76 Super (x 2), 74 Primavera (x 2), 06 Fly 150
Posts: 5579 Location: So Cal |
![]() SoCalGuy wrote: What the heck is this thing for? |
![]() ![]() 79 P200E, 62 Allstate, 2008 Stella
Posts: 1946 Location: Florence, OR |
![]() Maybe after you bend it to that shape you can catch one mounting hole and a fin or two? Hmmm, trippy looking device. Maybe it's made to double as a whisker for a big vat of cream....OK, maybe not.....
bodgemaster
![]() Yeah wondering how a bent piece of wire holds a flywheel. Doubles as a marshmallow roaster?
bodgemaster
![]() 1974 Rally 200, 1974 Rally 200 with sidecar, Vespacross bike
Posts: 575 Location: Atlanta |
![]() You ordered the wrong tool.
http://www.scootermercato.com/Scooter-Parts/Electronic-Ignition-Kits/20095400 |
[ Time: 0.1983s ][ Queries: 28 (0.0373s) ][ Debug on ] |
