Malossi 166 single piston ring piston
73 & 74 Rally, 76 ET3, 80 P200, 06 PX150, 61 Ser 2, 65 Silver Special, 86 & 96 Elite 80s, 2015 HD Road Glide Special, 2011 Ural Tourist
Mon Jan 11, 2021 11:54 pm quote
Does anyone know if the Malossi 166 kits ever came out with a single ringed version? A Stella guy near me was sold a used 166 kit with a single ringed piston. Sadly the kit is well used and piston rattles inside the cylinder. I told him Id sell him a Polini 177 I had sitting in my garage and give him some credit for the Malossi 166. Ill hone it and put on the shelf for the next guy needing a kit.
So, did Malossi 166 kits ever come with the single ring (Mark 1 kit maybe?) And question number 2, does it matter if I swap pistons to the 2 ring (Mark 2 version)?
Thanks guys
Jet Eye Master
Tue Jan 12, 2021 12:21 am quote
MHR177 piston should fit. It is single ring.
Tue Jan 12, 2021 5:09 am quote
I know that early and race-y small frame stuff came with a single ring, so Id assume that a very early 166 would be the same?
Id be interested to see it, in that the single ring version of a 130 I have is totally different than the 135 piston with duals.
-g
Tue Jan 12, 2021 3:05 pm quote
Measured 60.7mm on the piston. Underside of the piston shows CDC BRLY and ASSO-W 2544
Tue Jan 12, 2021 3:07 pm quote
Previous owner had to grind off the Malossi cast into the side to get it to fit the electric start flywheel.
I looked on SIPs site and all the 177 pistons are 63mm. Old 166 pistons are 61mm. Anyone got a link to a working single ring piston?
Wed Jan 13, 2021 6:24 pm quote
So Ive tried the usual domestic and foreign shops for a single ring piston in the 60-61mm size but cant find any. Im thinking I could go double ring and get by that way unless anyones got any ideas/ generic piston from someone else????
1980 P200E , 2005 Stella 177
Wed Jan 13, 2021 6:30 pm quote
The transfer and boost ports in the 2 ring piston later malossi 166 kit are nearly identical. The only difference I can see is the two side skirt openings are one big one on mine and a small above a medium one on each side on yours.
I would guess that a 2 ring piston for later malossi 166 kits like mine would work fine, but I'm just guessing.
later 2 ring piston malossi 166 kit (166 mkIII)
Your Rally Here   DoubleGood Vespa T-Shirts   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.3587s ][ Queries: 27 (0.0627s) ][ Debug on ]
