Hi fellow Vespa owners !
It is a 2011 LXV150ie that I just purchased used with 1200 miles. It has been dropped by the original owner so I knew there was oil in the air filter box. When I opened the air box a lot of oil came out so I cleaned it all and replaced the filter. I checked the oil level and it was real high so it looks like the original owner ran it after the drop and when the oil light came on they overfilled it with oil. I went ahead and changed the oil and got it down to the middle of the dipstick marks. However, after using half a tank of gas the clear bubble started to fill up with oil again and when opening the air box there is lots of oil in the box. Can't understand why that is happening after I cleaned the air-filter and there is no extra oil in the engine. Anyone has any thoughts?
Not sure if the bleeder valve can go bad and allowing oil to go through but not sure if there is something in it that can break.
thanks in advance.
