Where to grease steering tubes
2008 MP3 500
Sat Feb 06, 2021 11:10 pm quote
I just recently bought a 2008 MP3 500 and was reading some of the forums and they talk about greasing the steering tubes. I not sure where you do that. I know you need to buy some grease bolts. Does anyone have a picture of where these bolts go. Thanks
2015 MP3 500 ie Business
Sun Feb 07, 2021 2:23 am quote
The attached document explains the procedure in detail. Besides the bolt, you will also need a automotive grease gun, and a cartridge with bearing grease.
[/img]
3 wheel grease tool.pdf
 Description:
Download
 Filename:  3 wheel grease tool.pdf
 Filesize:  1.3 MB
2009 MP3 400, 2004 Honda ST1300
Sun Feb 07, 2021 6:24 am quote
You really only need to buy one of the grease bolts.
Remove the original bolt, put in the special fitting, pump in the grease, then put the original bolt back in place.
2008 MP3 500
Sun Feb 07, 2021 9:06 am quote
Thank you
Thanks for clearing this up for me. I wanted to get this done before riding season comes around.
MP3 500, GTS 250 (both 2008 MY), 2012 Honda NC700 DCT, 2014 Can Am Spyder RT
Thu Feb 11, 2021 6:20 pm quote
You will also want to be sure the bearings are properly adjusted.
If I recall correctly you basically loosen the top lock nut, then loosen the adjuster, tighten it against the bearing, back off 120 degrees, then tighten the lock nut against it.
The point is, the bearing should be slightly loose. Tiny bit, not wiggly.
Tight bearings will notch within several thousand miles.
Mine has ~47,000 miles on it with no notch.
Gts,mp3
Fri Feb 12, 2021 8:31 am quote
Hi there is a good video on youtube
2008 MP3 500
Fri Feb 12, 2021 8:55 am quote
Thanks for the tip on adjusting the bearings. I'll look for the video on You Tube.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   DoubleGood Vespa T-Shirts   Cool Ass scooter seat cover
[ Time: 0.1508s ][ Queries: 27 (0.0344s) ][ Debug on ]
