Sirs,
I own a 2008 Piaggio Malossi Fly 4 Tempi
Build Date: January 2008
VIN: ZAPC446BU84000441
How can I confirm what engine this scooter has?
Is it a 2-Valve or a 4-Valve?
Thanks!
What Engine, 2008 Piaggio Fly 50 |
Post Reply Forum -> General Discussion |
Author | Message |
![]() Sirs,
I own a 2008 Piaggio Malossi Fly 4 Tempi Build Date: January 2008 VIN: ZAPC446BU84000441 How can I confirm what engine this scooter has? Is it a 2-Valve or a 4-Valve? Thanks! |
![]() Not sure how similar they are but on the same era LX50 they are 2 valves from 2006 - 2009 and went to 4 valves in 2010 if I understand correctly.
![]() Kevin T
I appreciate your Reply. From various websites that I've researched Piaggio uses a Vespa engine that is approximately 2 years behind Vespa's latest generation. Another thing that I've come across leads me to believe that the engine is possibly a 4-T 2-V, but I have not been able to confirm that. I wonder if there is any website that translates the VIN like with vehicle manufacturers? The eighth digit of the vehicle VIN is, or was back when I was in the car business, the engine designation. I really do appreciate you at least giving me some indication that it is a 2 valve engine. Thanks! |
![]() ![]() 2006 LX150 (carbed) | 2007 GT200
Posts: 1232 Location: Toronto |
![]() Hi and welcome.
![]() Is it almost due for a valve clearance check? Open it up and count the valves! ![]() |
![]() ![]() In garage: Yamaha Tricity 155 Urban 2019 - MV Agusta 125 RS 1956
Posts: 5053 Location: Latina (Italy) |
![]() https://web.archive.org/web/20080921020434/http://www.it.piaggio.com/media/scheda_tecnica_fly_50_4t.pdf
Engine also installed on Piaggio Vespa Sprint 50 4T: http://www.laninisrl.it/product/10/24659/vespa-sprint-50-4t-bianco-innocenza Motore: Monocilindrico Hi-Per4 4 tempi, con catalizzatore a 3 vie e sistema aria secondaria SAS Cilindrata: 49,9 cc Alesaggio/corsa :39/41,8 mm Ammissione/distribuzione: 4 valvole, monoalbero a camme in testa Avviamento :Elettrico e a kick starter Lubrificazione: A carter umido Frizione: Automatica centrifuga a secco con tamponi smorzatori Cambio :Variatore automatico CVT con asservitore di coppia Welcome to Modern Vespa from Latina, Italy. ![]() |
![]() valve cover on 4t 4v say "quattro" raised casted letters
the 4v motor reached usa in 2012 for vespa, not sure with fly fly motor and vespa motor are not interchangable. the head and cylinder would be the same. after that there are many differences. |
![]() Piaggio 50 4-stroke 4-valve it reached the USA in 2012 but was certainly in production much earlier ... and has been used for other chassis models; example the Piaggio Leader... is also installed on many different models. Heck, it was also fitted to Aprilia,Peugeot, Malaguti and other brands.
![]() ![]() 2010 S50 Modified "Punkin"; 2003 ET4 Malossi 187 "ISO"
Posts: 668 Location: Deepinnaharta, Texas |
![]() Greetings:
Quoth jerryd: Quote: the 4v motor reached usa in 2012 for vespa, not sure with fly ![]() ![]() ![]() |
![]() I only just replaced the engine in 2012 vespa 50 4t 4v. regardless of when it was made or how many scooters it came in I was completely unimpressed with its performance in stock form. most boring vespa I have yet ridden. I couldnt believe the customer wanted it fixed after I fixed it.
![]() Greetings:
Quoth JerryD: Quote: I was completely unimpressed with its performance in stock form. most boring vespa I have yet ridden. I couldnt believe the customer wanted it fixed after I fixed it. |
![]() Wheelman-111 wrote: Greetings: Quoth JerryD: Quote: I was completely unimpressed with its performance in stock form. most boring vespa I have yet ridden. I couldnt believe the customer wanted it fixed after I fixed it. |
![]() Greetings:
KevinT, I split my riding time between 2 Vespas and a 2001 Honda SA50/72. Consequently, with local post office and dry cleaning runs being the majority of my rides, the miles add up slowly. I have heard that the Leader with the Malossi 187 runs to about 40K before crank issues arise, but the cylinder in one case was reinstalled on a second crankcase and went another 40K. The 187 often doesn't crank through compression on the first stab of the Start button, but also runs like a stocker once ignited. My S50/78 has just over 2K miles, starts and runs without a hiccup. The crankshaft on this one appears to be beefy for a 50, and I don't anticipate a failure any time soon. ![]() |
![]() Wheelman-111 wrote: Greetings: KevinT, I split my riding time between 2 Vespas and a 2001 Honda SA50/72. Consequently, with local post office and dry cleaning runs being the majority of my rides, the miles add up slowly. I have heard that the Leader with the Malossi 187 runs to about 40K before crank issues arise, but the cylinder in one case was reinstalled on a second crankcase and went another 40K. The 187 often doesn't crank through compression on the first stab of the Start button, but also runs like a stocker once ignited. My S50/78 has just over 2K miles, starts and runs without a hiccup. The crankshaft on this one appears to be beefy for a 50, and I don't anticipate a failure any time soon. |
![]() Piaggio uses the same bottom end in an 80cc and a 100cc version for different models and markets, so it should be able to hold up to an 80cc kit pretty well.
Here's the easy way to tell the difference... If the spark plug is a CR8EK, it's a two valve. If the spark plug is something you'd expect to find in a tiny little engine, and a PITA to remove, it's a four valve. The Earliest version of the 4 Valve engine I can recall was in the Aprilia Scarabeo 4 stroke, around 2006. |
![]() Motovista wrote: Piaggio uses the same bottom end in an 80cc and a 100cc version for different models and markets, so it should be able to hold up to an 80cc kit pretty well. Here's the easy way to tell the difference... If the spark plug is a CR8EK, it's a two valve. If the spark plug is something you'd expect to find in a tiny little engine, and a PITA to remove, it's a four valve. The Earliest version of the 4 Valve engine I can recall was in the Aprilia Scarabeo 4 stroke, around 2006. ![]() |
[ Time: 0.1628s ][ Queries: 27 (0.0412s) ][ Debug on ] |
