Tue Feb 16, 2021 5:46 pm
My scooter hasn't been ridden in over a year, and needs some love. I know I need new tires and battery, but would like to spruce the girl up a bit. Maybe more power? Bigger exhaust? A charging outlet for the phone? Better horn?
I'm looking for suggestions here. If you had $1000 to put into your scooter, what would YOU do?
2010 S50 Modified "Punkin"; 2003 ET4 Malossi 187 "ISO"
Joined: 18 Feb 2017 Posts: 668 Location: Deepinnaharta, Texas
Wed Feb 17, 2021 4:37 am
Greetings:
Your described and necessary replacements, for sure. I wouldn't hesitate to spring for the Malossi 187 kit, along with a stronger Delta clutch and variator to go along with your new belt too. As is, the acceleration will wake up! If you go with an upgear kit, acceleration is still better than stock, and opens up 70 MPH with the cylinder. You might even have some change left over from the G.
My 2 cents.
Wed Feb 17, 2021 7:09 pm
That's a definite maybe. I've thought about doing it every season; maybe this year is the time.
Any idea where I could find a kit to wire up a phone charger?
2018 GTV300 SG, 2012 LXV 125ie 2V, 2015 Primavera 3V 150ie and V90
