Does the green seal in this photo look okay?? I it appears to extend abit further (a millimeter or two) at some points on the seam than others... at some points it’s flush. Thanks again.
I would say that is normal. Is there anything indicating that the gasket was compromised in any way, or is it just the irregularities of what is exposed that has gotten your attention?
Gaskets are mass-produced with a die-cutter to match approximately the facing surfaces of the castings they seal. Sometimes they don't match precisely. Sticky-outie is good. I worry more when I CAN'T see the gasket than when I can.
Thanks everyone. I have no reason believe the seal was compromised.... except for perhaps me scraping it from the exterior with a totally mangled oil filter that was extremely difficult to remove and must have been installed by Hercules (or the Italian demi-god equivalent).
But it's a near brand new bike. A new bike that has been standing so gaskets don't get dirty. Even my own GTS in it's 5th year still has gaskets on the engine that look almost new. So I don't see any reason to be suspicious.
Correct, the bike is from 2018 and has 3 miles on it, so the seal has not been replaced.
