WTB: Malossi 7.2 weight, only just need 1 or 6.5 for the hil
Et2
Fri Feb 19, 2021 2:12 pm quote
VESPA ET2 with 70cc kit and Malossi clutch: Some how I lost one 7.2 malossi roller, only thing holding me back from finishing this project. Does anyone have just one to sell me?
Or what if I just use a 6.5 stock roller set, I think I have a set somewhere. Would that be better for hilly areas?
Thanks for input?
2010 S50 Modified "Punkin"; 2003 ET4 Malossi 187 "ISO"
Fri Feb 19, 2021 7:04 pm quote
Greeting:
Lighter rollers raise the average RPM of the engine , arguably improving performance on hills, assuming they're not OVER-revving the engine.
Lots of Honda 50 modders mix their rollers when they don't have the correct gram weights to achieve the desired total mass. The Reflex 250s even came standard with 3 light and 3 heavy rollers from the factory. The Big Ruckus, with the same engine, had all 6 weights the same and it worked better.
Using a single 6.5 gram roller with a gang of 5 x 7.2s will cause an imbalance on the crank end, however slight. If you're going to use a 6.5, I'd recommend you install 2 and place them opposite each other to maintain batter balance in the variator casting. It will probably not make a huge change, but the RPM should go up a little for a given drive load.
Et2
Fri Feb 19, 2021 10:01 pm quote
I was just thinking the same think! Good to know others are doing it. Iím going to look for those stock rollers..
Sponsor
Granturismo 218
Sun Feb 21, 2021 4:33 pm quote
With a 70cc kit, something in the mid 5 gram range usually works better than the stock weights.
Cross Egypt Challenge - A 2400km ride throughout Egypt   DoubleGood Vespa T-Shirts   Cool Ass scooter seat cover
[ Time: 0.1391s ][ Queries: 25 (0.0326s) ][ Debug on ]
