Hi folks,
I have a Vespa GTS 300 HPE with 1,500 km on the clock. The bike is great fun to drive but I am not satisfied with the braking. Emergency braking when cruising at 80 km/h can be scary (I am also driving big bike where I am used to powerful brakes).
I believe that better shocks absorbers and brembo brakes should improve this a bit. I have red several threads about shock absorbers and it seems that Biturbo and Malossi are of similar quality. No one recommend Ohlins?
Have you tried the Brembo brakes? Is is possible to also put a larger front disk? The ABS will still work same? I have seen any post on this.
Thank you for your recommendation !
