Weekend of fun and then pop! Holed piston
73 & 74 Rally, 76 ET3, 80 P200, 06 PX150, 61 Ser 2, 65 Silver Special, 86 & 96 Elite 80s, 2015 HD Road Glide Special, 2011 Ural Tourist
Sun Feb 21, 2021 3:20 pm quote
Just got back from a Thursday to Sunday camping trip in the desert with my friends. One of which is the owner of a 63 VBB that I recently added a Vape kit to. Spent all weekend riding around Borrego Springs/ Salton Sea area. This morning, we went out on a breakfast ride and hit some gnarly headwinds. Im not sure if its the headwinds that did it, or some shit gas, but I holed the piston on my trusty 74 Rally.
Motor is a stock cylinder, Pinasco Flytech ignition and a Sip Road 2.0. Jetting is in the mid 120's IIRC. Its been two years since I touched that motor and its been dead reliable. I was full throttle high revs, high load but low speed. Anyone ever heard of that combination causing a holing scenario? Or do you think its shit gas from the desert gas stations?
Beautiful 70* days everyday. Little chilly in the evenings
Indiana. My sisters dog
63 VBB. 2 port 177 kit, 24/24, Vape, Sip Road 2.0 and the rest is stock 8"
Settled on a 160, be3, 135. Wide open for two miles and temps never got above 360*
Nowheresville
Waiting for the Mrs. to come grab me
My two
Jet Eye Master
Sun Feb 21, 2021 3:32 pm quote
At least you were on the way home!
This is exactly what happens when the timing is way too strong. If variable timing, it's at least 4 degrees over at the rpm where it holed the piston.
GS 66.5mm piston. Adjust timing, full rejet. If splitting the engine to clean it out, add a 60mm crank to that list. Will go cross country touring with that lot and WOT all the way.
Sun Feb 21, 2021 3:40 pm quote
Jack- yes it’s variable timing. Do you mean it’s 4* too advanced for that rpm or 4* retarded. I think Pinasco idles around 24/25 and then retards to 17??? It’s been a while.
1952 Allstate 1955 Allstate 1958 lambretta 1965 Allstate 1968 sprint
Sun Feb 21, 2021 4:02 pm quote
Holed piston
Hey MJ....that scooter has been running strong like you said for two years, it would have ran for 5 years, but when was the last time you ran the scooter like you said. That scooter was not used to that kind of punishment especially with the timing being to advanced. If there is a time that the timing needs to be right
on you found it. I can’t think of anything else that would cause that situation other than timing and the engine running lean, or both.
Have not heard from you in a while. Hopefully we can catch up in slo (rom)
Hope all is well scott
Jet Eye Master
Sun Feb 21, 2021 4:09 pm quote
Too far advanced. Setting up by the book is where all the trouble starts. Where ever your stator is set move it 4 (approx) mm clockwise.
Going to split it to clean, or hope for the best?
Sun Feb 21, 2021 4:18 pm quote
Aye advanced. I’ll do it right and split it. Pics soon
Sun Feb 21, 2021 4:21 pm quote
Re: Holed piston
Haven’t forgotten you Scott. Just havent been in your neck of the woods lately. Last time I flogged this one that hard was probably a year ago. Rest of it has been stuff around town/ down to San Diego. I’ll pull the head soon and get back with pics.
Sun Feb 21, 2021 5:24 pm quote
Cleaner than I would have wanted it to be. 160, BE3, 128 SIP (125 equivalent
1980 P200E , 2005 Stella 177
Mon Feb 22, 2021 2:12 pm quote
damn! but that is a beautiful scoot nonetheless! Also looks like some great rides out there.
79 P200E, 62 Allstate, 2008 Stella
Mon Feb 22, 2021 2:36 pm quote
NOOOOOOOO! That's bites. But hey, at least you're in the 60/8 club
Jet Eye Master
Mon Feb 22, 2021 3:52 pm quote
Jetting over stock so, hole like that can only be timing.
Going to change the crank? It should be ok, aluminum should clean itself out of the big end bearing but if you change crank, a 60mm is really good in a stock cylinder. GS piston is better in every way over the meteor. If you're going to do the work it might as well be 10mph faster.
Mon Feb 22, 2021 5:47 pm quote
[quote="Jack221"]
I'm going to remember and do this when I open up my P200
Thu Feb 25, 2021 8:14 am quote
Didn't SIP post something up a year or so ago that they didn't recommend installing their variable Vape kit on a stock cylinder? Whether it was user install with the kit or if the kit doesn't play well with a stock cylinder, one thing is for sure, there has been a fair amount of scooters with stock cylinders with variable Vape and holed pistons. So there is a correlation there for sure.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.1654s ][ Queries: 25 (0.0300s) ][ Debug on ]
