tilt lock pressure switch replacement
MP3 400
Wed Mar 03, 2021 3:57 pm quote
Hi,
Tried to replace tilt lock pressure switch on 2009 MP3 400 but could not remove blue electrical connection to access switch. How is that done. Any special tool needed?
Gilera Fuoco 500ie
Thu Mar 04, 2021 5:32 am quote
a flathead screwdriver
MP3 400
Thu Mar 04, 2021 9:19 am quote
I'm afraid I'll break the blue plastic
2015 MP3 500 ie Business
Fri Mar 05, 2021 1:02 am quote
The screwdriver is only used to release the tang that holds the connector to the sensor. There is no need to go Samsonite monkey on it.
If you are afraid to break something, then better have it done by somebody that knows these bikes.
MP3 400
Fri Mar 05, 2021 8:43 am quote
I got it off. Used the flat screwdriver (gently) and it slid right off.Many thanks for the guidance
MP3 500, GTS 250 (both 2008 MY), 2012 Honda NC700 DCT, 2014 Can Am Spyder RT
Sun Mar 07, 2021 12:55 pm quote
I think there are almost zero dealers in Hawaii that know the MP3 system.
Almost.
MP3 400
Sun Mar 07, 2021 3:32 pm quote
Yup,
Only 1 and they won't work on cycle over 10 years old!
Still can't find someone to show me how to bleed tilt lock. Some say push fluid uo from bottom with syringe? Can't figure out how that works unless you leave master cylinder for tilt lock open and push fluid up into cylinder.
Sun Mar 07, 2021 4:07 pm quote
bigdog wrote:
Yup,
Exactly that - and syringe it out occasionally to ensure it doesn't overflow.
MP3 400
Mon Mar 08, 2021 7:57 am quote
OK. Thanks for the reply. I'm gonna get moving on this task today!
  DoubleGood Vespa T-Shirts
[ Time: 0.3228s ][ Queries: 27 (0.0842s) ][ Debug on ]
