2013 Vespa lx ie
Tue Mar 09, 2021 7:17 am
NO CARB. 2013 150 lx ie won’t start. Getting power but just won’t start. It sat about 4 months. New Gas put in but no help. What next anyone please 😩
2007 LX150
Joined: 10 Oct 2017 Posts: 35 Location: Washington DC
Fri Mar 12, 2021 2:08 pm
Is it turning over? Are you getting spark? Is the fuel pump working? Lots that can be looked at, but you need to provide some more details.
2013 Vespa lx ie
Sat Mar 13, 2021 5:30 am
It’s turning over like it did before but I think it isn’t getting fuel to where it needs to be. I need a Diagram or Picture of the inside of the workings because it has No Carburetor and I want to be sure where the Petcock is, fuel and vacuum line.
Sat Mar 13, 2021 5:42 am
When was the last time the bike ran, and has anything been changed since then?
2007 LX150
Mon Mar 15, 2021 8:33 am
Just follow the fuel line from the bottom of the tank to the pump to the injector. The vac line(s) tie into the emissions evap canister. While that can prevent starting, it’s likely that it’s something else.
Can you hear the fuel pump prime when you turn on the ignition? My guess would be an issue with the pump or something else that’s preventing spark.
LX150ie
Mon Mar 22, 2021 6:11 am
Same thing happened to my LX 150ie twice when left unused for 6 months plus.
In both cases I replaced the fuel injector and fuel pump/filter assembly.
The plastic hose that connects the fuel pump to the main fuel filter gets brittle and eventually develops leaks that reduces pressure.
Runs and rides like new after that.
Joined: 21 Oct 2005 Posts: 8636 Location: The state of insanity, SoCal
Mon Mar 22, 2021 3:44 pm
like thefakebecky said, when you key it up you should hear the pump prime. it'll be a little subtle dut, dut, dut, dut
if you don't hear that, check your fuses and then check the pump.
if you do hear that, suspect the injector. pull it and hose it out with some brake clean and purge the system of all the bad gas and you should be cooking.
this is all predicated on it having the correct key and not showing an immoblizer code.
once you get it to pop and fart, it's time for a tune up.
hth
- g
