3100 original miles (last 1200 of them by me)
150cc, air-cooled, solid-running engine
Handful of minor scratches from being a 17-yr old scooter
$1800
Found in late 2018 and was my daily driver until I got a GTS in late 2019. Just don't find myself riding it enough to warrant keeping it. Top speed mid 50's. Did the following when I brought it home:
New fluids & filters: oil, trans, front brake (only front is hydraulic), air filter
Tires: lots of tread left, date codes are Sep 2017 (front), and Feb 2018 (rear)
Carb cleaning (by shop)
New CDI (by shop) w/master key
New Malossi kevlar belt
New Malossi variator rollers (9.3 grams)
New NGK Iridium spark plug
Brake light modulator (flashes when brake is applied for visibility)
Removed Evap system
If you're registering it in Texas, I'll get the inspection and registration current before you take it home. PM for more info. As is usual, test drives need cash in hand.
