Making a wooden scooter lift
2020 Piaggio Liberty 150
Sat Mar 20, 2021 8:58 am quote
These scooters are under 400 lbs mostly...I'd like to find a plan for a scooter lift that can be put up against a wall when not in use...thank you from northern vermont where the snow is not melting quick enough to get the rig out of the cellar...put a lot of time on it down there...
GTS 300ie Touring - Signora D'argento
Sun Mar 21, 2021 1:47 am quote
I was considering buying this one, although it looks like quite a steep ramp to get your scooter onto the table. I like the idea that the ramp converts into a seating bench......
https://www.sealey.co.uk/product/5637191863/360kg-motorcycle-portable-folding-workbenchpit-table
There's also an old thread from some DIY projects.....
DIY Work Bench/Ramp
Andrew
Sun Mar 21, 2021 2:23 am quote
Here's one designed to be stacked aside:
My DIY Knock-Down Work Stand
Welcome to Modern Vespa!
  DoubleGood Vespa T-Shirts
[ Time: 0.1229s ][ Queries: 23 (0.0198s) ][ Debug on ]
