2013 GTV 300 won't start or even turn over
GTV300
Sun Apr 04, 2021 12:07 pm quote
What's your best guess as to why my best but won't start? When I push the start button there's absolutely no noise whatsoever. No clicking, no attempt to turn over. I do hear the whirring noise for the first second or two after I turn the ignition on. I'd appreciate any help.
Sun Apr 04, 2021 12:59 pm quote
Did you check the brake light comes on when you pull in either brake lever? The most common reason for no action from the starter relay is when one or both brake light switches have failed - yes, they do get dirty inside. Very cheap and easy to replace, they are one of those things you should always have as a spare, along with exhaust gasket, spark plug etc.
Sun Apr 04, 2021 2:42 pm quote
If not the brake lights then try the kill switch.
MP3 500, GTS 250 (both 2008 MY), 2012 Honda NC700 DCT, 2014 Can Am Spyder RT
Sun Apr 04, 2021 2:58 pm quote
And if not the kill switch, maybe put some gas in the tank.
GTV300
Mon Apr 05, 2021 5:43 am quote
Thanks for your input. Yes, brake lights work. Kill switch is in the correct position.
Could the kill switch be faulty? Any other ideas?
GTS300
Mon Apr 05, 2021 6:04 am quote
Have you tried the brown master key
I had this problem with mine and it turned out to be a faulty key
Cheers
Mon Apr 05, 2021 7:03 am quote
Re: 2013 GTV 300 won't start or even turn over
Next step - what does the red Code LED on the dashboard do? The number and timing of flashes is important, and whether the LED then goes off or stays on.
GTV300
Mon Apr 05, 2021 9:53 am quote
When I turn the key to the "on" position, the red LED light blinks once for maybe 1 second. Then a pause, then 2 more shorter blinks (so three blinks total). Then the red LED light turns on and stays on.
Mon Apr 05, 2021 3:51 pm quote
You have a dodgy aerial or connection between the aerial and the ECU.
Read all about it in the workshop manual (the GTS is the same as the GTV for this):
https://manuals.wotmeworry.org.uk/Vespa/GTS300%20Super/
GTV300
Tue Apr 06, 2021 7:21 am quote
So helpful. Thanks! Vespa started with original brown key. My other key must be damaged. Greg
2016 Sprint S 150 (his), 2016 Sprint 150 Blu Gaiola (hers), 2006 GTS 250 Excalibur Gray (hers), 2006 GTS 250 Black (his), 2012 GTS 300 Daring Plum (he
Wed Apr 07, 2021 5:06 am quote
Get some new keys ASAP. My scoots came with the master key and a blue key. I bought some blanks, had them cut at Ace Hardware and then programmed them. I bought 2 extras for each scoot and keep one with the master in a safe.
  DoubleGood Vespa T-Shirts
[ Time: 0.1481s ][ Queries: 25 (0.0454s) ][ Debug on ]
