I took my 300 HPE for its first service recently. I asked if they had greased the bearings (to prevent the notch) - they said no as they were hard to get to etc and that it wasn't part of the first service. I think I was fed some BS there as they are not hard to get to, based on the pictures I have seen. However, is it correct that the first service does not involve greasing these bearings?
Piaggio Doesn't mention any greasing of bearing in the workshopmanual for service intervals
But it shows that the shop you went to doesn't know the mp3 Shops that sell and work on them a lot do it as a service it will save them a warranty repair |
Thanks for that. This was the main dealer in the area! Looks like I'll be finding somewhere else.
Posts: 43354 Location: Pleasant Hill, CA |
It's an easy DIY - from Piaggio just buy the special bolt that has a Zerk fitting, and one by one over the four bolts top and bottom of each leg (IIRC) replace with the new one in turn, pumping grease in until it oozes out of the nearest bearing.
jimc wrote: It's an easy DIY - from Piaggio just buy the special bolt that has a Zerk fitting, and one by one over the four bolts top and bottom of each leg (IIRC) replace with the new one in turn, pumping grease in until it oozes out of the nearest bearing. https://scooterpartsco.com/ricambi/030-piaggio/piaggio-mp3-tool-with-grease-fitting-020943y Its a bit expensive but I'm considering having it installed at the next major service for my bike as an investment in the future. Also. Folks, if "buy this" is the solution, please include the part-number or vendor/dealer URL to the part. Allot of us beginners struggle to zero in on the correct part from a good vendor OR have trouble digging through old forum posts. http://ec2-50-18-170-78.us-west-1.compute.amazonaws.com/forum/topic155737 |
pinheadh78 wrote: jimc wrote: It's an easy DIY - from Piaggio just buy the special bolt that has a Zerk fitting, and one by one over the four bolts top and bottom of each leg (IIRC) replace with the new one in turn, pumping grease in until it oozes out of the nearest bearing. https://scooterpartsco.com/ricambi/030-piaggio/piaggio-mp3-tool-with-grease-fitting-020943y Its a bit expensive but I'm considering having it installed at the next major service for my bike as an investment in the future. Quote: Also. Folks, if "buy this" is the solution, please include the part-number or vendor/dealer URL to the part. Allot of us beginners struggle to zero in on the correct part from a good vendor OR have trouble digging through old forum posts. Bolt With Grease Fitting |
Re: First service
imadequavers wrote: I took my 300 HPE for its first service recently. I asked if they had greased the bearings (to prevent the notch) - they said no as they were hard to get to etc and that it wasn't part of the first service. I think I was fed some BS there as they are not hard to get to, based on the pictures I have seen. However, is it correct that the first service does not involve greasing these bearings? Be careful, a lot of people just BS.... |
abcdef wrote: That happened with me too, with a Piaggio Dealership, when I asked him about greasing the bearing as part of the service they do, the staff stated yes, when I sent it for service, they did not do it, upon asking why, they stated it is a separate job and it will cost a lot, it was the last time I sent it ,and I left a negative review on this dealership. Be careful, a lot of people just BS.... |
imadequavers wrote: Did you then do it yourself or did you get someone else to do it? I recommend that if you want do the steering bearing service which is changing the bearing etc.... to let the dealership to do it as they are qualified to do it. A person may know how to do some aspects of it, but if anything is done wrong they will not know and it will be your life as you are riding it. But for the topping up the grease, if you are handy, it is a very basic job and you can do it. Good luck. |
imadequavers wrote: I took my 300 HPE for its first service recently. I asked if they had greased the bearings (to prevent the notch) - they said no as they were hard to get to etc and that it wasn't part of the first service. I think I was fed some BS there as they are not hard to get to, based on the pictures I have seen. However, is it correct that the first service does not involve greasing these bearings? |
The whole job takes less than 1 hour for a dealer or trained mechanic to do start to finish, including fairing removal.
I use a car ramp to get the MP3 tilting mechanism as extended as possible. Lubing all 4 bearings is a 10 minute deal then since I don't need to remove the fairing. Removing the grease that squeezed out from the bearings takes the most time since you can only access the front half. |
sbaert wrote: The whole job takes less than 1 hour for a dealer or trained mechanic to do start to finish, including fairing removal. I use a car ramp to get the MP3 tilting mechanism as extended as possible. Lubing all 4 bearings is a 10 minute deal then since I don't need to remove the fairing. Removing the grease that squeezed out from the bearings takes the most time since you can only access the front half. Do you have to remove the grease or topping it up when you do that service? I was informed to top it up only but no one mentioned to change the grease, if to change the grease how do you do it? thanks, |
Posts: 7542 Location: Madison, Wisconsin |
abcdef wrote: Not every mechanic does want to do the job as fast and good as possible, one of the dealers (whom I mentioned above that told me it is a separate job), had a person (not calling a mechanic) as snails were faster than him in working, walking with extra slow motion.... as he charges by the hour, that is one mistake in life taking my scooter to him. Do you have to remove the grease or topping it up when you do that service? I was informed to top it up only but no one mentioned to change the grease, if to change the grease how do you do it? thanks, |
One more thing, greasing the headstock bearings should be part of the normal service schedule, ideally every 5K - max 10K km intervals or whenever doing a oil change.
The headstock bearings are the grief of the MP3, and if the bike never had its initial 1K service done which includes readjustment of said bearings have it done asap and then just keep regreasing at the stated intervals. No idea why Piaggio does not include this in their manual, but I'll rack that up to their lack of care in the same manner their manual states the incorrect engine oil fill capacity. |
sbaert wrote: One more thing, greasing the headstock bearings should be part of the normal service schedule, ideally every 5K - max 10K km intervals or whenever doing a oil change. The headstock bearings are the grief of the MP3, and if the bike never had its initial 1K service done which includes readjustment of said bearings have it done asap and then just keep regreasing at the stated intervals. No idea why Piaggio does not include this in their manual, but I'll rack that up to their lack of care in the same manner their manual states the incorrect engine oil fill capacity. |
