Ignition Barrel
Gilera Fuoco 500ie LT
Mon Apr 05, 2021 2:55 am quote
Hi I would just like to ask if is possible to fit a ignition barrel from a mp3 500 to a Fuoco 500 or if any body knows an easy fix? If you turn the key nothing happens you have to wobble it about to get it to turn on but then you can take the key out with the ignition on. any ideas?
Mon Apr 05, 2021 4:27 am quote
the ignition barrel from any mp3 will work. they are all the same.
but none would be plug and play. the chip inside your current key must be transferred to new key.
Mon Apr 05, 2021 5:31 am quote
That's great thanks is there anyone braking an MP3 who has the ignition with all it's keys
Mon Apr 05, 2021 6:19 am quote
https://scooterpartsco.com/ricambi/030-piaggio/ignition-switch-and-keys-for-piaggio-mp3-624441?zenid=2dbdf4333f2e09e3e380641358492b0b
the ones on ebay are over priced. this is cheapest I found for you
2008 fuoco
Mon Apr 05, 2021 2:30 pm quote
If your in pembrey Wales UK then put - breaking piaggio mp3 in ebay and you will find plenty of people breaking mp3s, just ask them ,some have there mobile numbers hidden in there listings. Beware of buying from outside the UK at the moment due to the new import/vat rules.
  DoubleGood Vespa T-Shirts
[ Time: 0.2434s ][ Queries: 25 (0.0426s) ][ Debug on ]
