I have a good battery 12. 7V ... checked when I try to start nothing. everything cycles on... the red code light flashes twice then goes solid ?
I can hear the pump cycle but it will not start the starter does not turn at all .. strange because it started I rode a bit then it stopped in the driveway luckily so I was not stranded ..
what can I check , battery is good, fuses are good ? any idea what I could be I did have the seat up and the basket out... I read something about the immobilizer .. it it was moved with the key out I am not sure how that works ? how do you reset the immobilizer ?
2012 300 GTS 1700 MILES
