EZ Pass Holder ??
2018 Piaggio BV 350
Tue Apr 06, 2021 3:43 pm quote
EZ Pass in NYC is going to start fining/charging a higher rate if your ezpass is not mounted to the windscreen. I've got the smaller, newer transponder. It won't stick on (I've tried three different times), and I'm not sure how others have mounted it up to now. Please help with suggestions/products! I've tried on other areas by the tachometer, but there's not a flat area in there. Please help, thank you!!
MP3 500, GTS 250 (both 2008 MY), 2012 Honda NC700 DCT, 2014 Can Am Spyder RT
Tue Apr 06, 2021 3:53 pm quote
Illinois IPASS has a transponder you can screw onto your rear license plate bracket.
Medley 150
Tue Apr 06, 2021 4:00 pm quote
Leave it in your jacket pocket.
Tue Apr 06, 2021 4:02 pm quote
You can get magnetic ones apparently. https://www.google.com/search?q=magnetic+ezpass+holder
Tue Apr 06, 2021 4:14 pm quote
What are you supposed to do if your motorcycle does not have a windscreen?
2018 Piaggio BV 350
Tue Apr 06, 2021 4:22 pm quote
Good question; My guess is they use the holders transfixed to the handlebars but it's not an option with my ride. :/
My jacket only has pockets on the side, not the arm and I don't think it'll get picked up, so then I'll be stuck with the fine.
Tue Apr 06, 2021 4:28 pm quote
Will it mount to a mirror?
Tue Apr 06, 2021 4:35 pm quote
How about this?
http://modernvespa.com/forum/topic100385?highlight=bv350+ram+mount
or this
http://modernvespa.com/forum/topic143046?highlight=bv350+ram+mount
Attach the transponder to a RAM GPS or phone holder.
Tue Apr 06, 2021 4:57 pm quote
3M makes a product called Dual Lock reclosable fastener that's like heavy duty Velcro. Its super sticky adhesive should stick tight to your windscreen and the transponder. It comes in black and clear, and you can find smaller pieces of it it in hardware stores.
https://www.amazon.com/3M-Dual-Lock-Reclosable-Fastener/dp/B007OXK1AK
2018 Piaggio BV 350
Tue Apr 06, 2021 5:08 pm quote
I bought this exact thing today. Iím going to wash the scooter good weekend and try again. It wasnít sticking when i tried that.
Tue Apr 06, 2021 5:11 pm quote
It may help to clean the surfaces with alcohol. Beware -- the Dual Lock will probably leave a permanent mark on a plastic windscreen!
VSX, Stella 177, VNX1T, V9B1T
Tue Apr 06, 2021 5:16 pm quote
I bought this a few years ago.
https://www.blackbeardsgear.com/online-store/Toll-Pass-Motorcycle-Holder-p111638996
í20 GTS 300 hpe
Tue Apr 06, 2021 5:20 pm quote
I am using the hook and loop strips I had requested from E-ZPass (free of charge) for my newer style tag, which is securely mounted to the inside of a short screen.
2018 Piaggio BV 350
Tue Apr 06, 2021 5:26 pm quote
Do you have any pics?
2019 Piaggio Liberty 150
Wed Apr 07, 2021 5:45 am quote
I leave the EZPass transponder in the front glove box on the Liberty and the other EZ is in the upper cubby on the Silverwing. They always register for me. But my friend took a lanyard and made a EZPass holder. I know another motorcycle rider who made a wrist wrap holder outta velcro. I always wear my safety vest and used to put it on the badge holder, but mine work in their hidden locatios so far. Why can't EZPass just do the pay by plate at the EZ rate like they used to?
2018 Piaggio BV 350
Wed Apr 07, 2021 6:03 am quote
Oh, they do! But if it's not properly mounted, I get charged more. So, basically, a penalty. If it's toll by mail, it's a higher rate (per their website, going into effect on Monday).
2020 GTS 300 HPE
Wed Apr 07, 2021 7:01 am quote
That's literally the Handleband. It's designed to hold a cell phone on a bicycle - I think it was a Kickstarter. You can probably find one at a local hardware store or bike shop.
2015 GTS 300 Super (Melody)
Fri Apr 09, 2021 10:16 am quote
Re: EZ Pass Holder ??
What does the new transponder look like?
This is an issue for me as well: whatever pocket I end up putting the thing in, it registers in some toll stations but not others. Last time I used an industrial-strength Velcro setup, I hit a depression in the road hard enough to lose the transponder.
S150, Beo 500ie
Fri Apr 09, 2021 4:58 pm quote
I thought I was in good shape by putting the transponder in the chest pocket of my riding jacket, but nope - after three rides this week the Henry Hudson Bridge read two out of three southbound, and zero out of three northbound. Might have to go with the stupid shoulder band.
Iím guessing a lot of errors, or maybe fraud, was going on with the license plate readers - turning 3s into 8s, for example - so theyíre incentivizing a return to the transponders. An annoying step back to the early 2000s technology.
í20 GTS 300 hpe
Fri Apr 09, 2021 11:34 pm quote
Velcro strips on Vespa to secure EZPass tag.
Sat Apr 10, 2021 7:03 pm quote
I might have found a solution (at least for someone like me with a windscreen):
https://www.ebay.com/c/2255529030
í20 GTS 300 hpe
Sat Apr 10, 2021 9:22 pm quote
You can save yourself the expense. E-Zpass will send you the hook and loop strips for free.
It's not like ordinary velcro, the tag mounts securely to the windscreen and with thousands of miles with this set-up (see the image above, strips to the right of the Beeline navigation unit), I can tell you that the mounting is NYC area rough road proof.
Sat Apr 10, 2021 9:40 pm quote
HmmÖwell, I ordered the thing already, so we'll see.
In fact, before I had the windscreen, I Velcro'd the thing to the underside of the handlebar housing; this worked for a while, but (1) it still was hit-or-miss with certain toll stations, and (2) I eventually hit a Ceres-class pothole which dislodged the transponder and jettisoned it who-knows-where. Now that I have the Flyscreen, we'll see hw things go.
Thu Apr 15, 2021 4:41 pm quote
Making It a Bit More "EZ"
Admittedly, this is a bit more involved that giallo's setup, but (1) this one doesn't require anything chemically adhesive to the windscreen, which I waned to avoid, and (2)I have the option to pull the thing off and place it anywhere else on the screen as I see fit. But, if you've got something that already works for you, stick to it!
EZ Pass Holder, *sans* Tag: Three suction cups hold it to the screen, and seem quite tenacious to that end.
EZ Pass Holder, with Tag: The holder comes with a set of closed-cell adhesive-foam strips to prevent the tag from rattling around in the holder; I embellished this with a single adhesive rubber dot.
EZ Pass holder, Front View
EZ Pass Tag, Embellished: There's only one small problem wit this setup: it's simple to pop the tag in, but not to get it back out. Solution: a pull-tab attached to the left side. I chose to use a length of Brother P-Touch tape, which also allowed me to
S150, Beo 500ie
Thu Apr 15, 2021 5:02 pm quote
I hope those suction cups withstand external conditions and adherence to the plexi (as opposed to glass).
My experience has been that they work well...until they donít.
Thu Apr 15, 2021 5:14 pm quote
These particular cups seem to be quite compliant, but I'll be checking them every few weeks or so to make certain. Also, they're not having to hold something particularly heavy.
Fri Apr 16, 2021 11:01 am quote
prob not super helpful but looked at a used vespa that had a easy pass box screwed on the left knee pad on the leg shield. not sure where it came from though.
  DoubleGood Vespa T-Shirts
[ Time: 0.3254s ][ Queries: 27 (0.0540s) ][ Debug on ]
