Vespa GTS 250 Headlight Modulator Install (Pics)
Thu Oct 25, 2007 2:04 pm quote
Hello friends,
I recently had the opportunity to install a Diamond-Star headlight modulator on a GTS 250. The wiring is fairly straightforward, but the tricky part is finding a location for the optic sensor! The optic sensor is required in the States because headlight modulation is illegal after dark, and the sensor allows the modulation to function only in the daylight hours.
I wasn't about to drill a hole in this guy's body panels. I've seen another modulator install that had the sensor in the rubber boot that fastens at the foot of the mirror. I could have done this, but I figured that I'd try to take a slightly more challenging gamble at it.
(The first two photos are large, so I added them as links instead of posting the photos themselves.)
http://www.scooterinvasion.net/pics/vespalightmod/P1010001.JPG
http://www.scooterinvasion.net/pics/vespalightmod/P1010002.JPG
Mounting the optic sensor there is NOT as easy as you'd think! There's a circuit board and some other goodies that prevent one from just drilling straight through the back of the instrument cluster to feed the sensor through. I didn't have the camera yesterday when I started the project, so unfortunately there's no pics of the beginning... shame though, there's a LOT of fancy dremel work underneath that sensor.
Every wire touched in this project is soldered.
Cheers!
~Josh
Thu Oct 25, 2007 9:34 pm quote
Nice job, but wow, that modulator is pretty intrusive!
The Comagination modulator doesn't require any wires cut and/or soldered. But then, its light sensor doesn't require much drilling, Dremeling or resining either.
PS: I think you qualify for the soonest modulator install of Vespakind, at 3 miles! Now, go and put some digits on that odometer!
PS PS: How did you manage to empty your tank to half with only 3 miles? Didn't they give you a full tank?
Dragon Red GTS 250ie
Thu Oct 25, 2007 10:29 pm quote
thank you very much..great job
Fri Oct 26, 2007 3:24 am quote
The Diamond Star is what I had to work with. I'll look into the Comagination one, perhaps the next one we'll use that! Thanks for the info. For what it's worth the Diamond Star doesn't require soldering. It comes with wire taps and connectors, but I prefer to solder things when working on a scooter or ATV or whatever else. I feel that in most cases, this is best. If the modulator ever fails it won't be as easy to swap out, but there's plenty of wire left if I have to go back in for anything.
Unfortunately, it's not my GTS. I'm trying to find a vintage bike myself to restore, but haven't found one that fits my budget yet. I did this for a fellow who was buying it. I'm sure he'll put PLENTY of digits on the odometer. Doesn't everyone who owns one of these fine machines?
Glad you like it. Thanks!
~Josh
Fri Oct 26, 2007 3:27 am quote
I assume this is it? The optic sensor looks like it's half the size.
~Josh
Fri Oct 26, 2007 7:10 am quote
Areomyst,
Is that how the Comagination comes now for the GTS? Mine had two of the three-wire connectors, one male, one female. Plug it between the scooter's light connector and the headlight socket, and you're done with that part.
Then, find a place to tuck the light sensor, and put it back together to ride more safely.
Nice of you to help a friend make his new GTS more visible!
I once gifted a modulator to a guy here on MV as a reward for a personal achievement, and he still hasn't found the time to plug it together
07 GTS250, Several Lambrettas
Fri Oct 26, 2007 3:19 pm quote
Several headlight modulators were installed at the MV Eastcoast Maintenance Workshop last weekend in Richmond.
There was a small tab and a gap on the rear (driver) side of the headset between it and the left handgrip. We bent the lead around the tab and peeled back the grip slightly, placing the sensor just flush with the rib of the left hand grip. Looked clean.
PX 150
Sat Oct 27, 2007 6:56 am quote
I just added a thread about installing Kisan modulators after having poor luck with Comagination units. Am I the only one for whom the Comagination units failed to work on a GTS? Can someone who has one installed rev their motor up with the scooter on the stand and see if the flash rate remains constant as it should? Mine flashed faster and faster as rpms went up, rendering the modulator useless (other than at idle).
Jeff
The tread I added is here: http://www.modernvespa.com/forum/topic17923.html
GT200
Tue Oct 30, 2007 9:19 am quote
Where is the best location for the sensor on a GT?
The Diamond Star instructtions say pointing downward & at least 18" above the street surface. I did that and the unit thinks its night waaay before dusk - like as early as mid-afternoon in open shade.
PX 150
Tue Oct 30, 2007 10:39 am quote
With the Kisan, the sensitivity is infinitely adjustable. Get up early one morning and when it is light enough that you want the blinking to start, you hit a sequence with the high/low beam switch and it is set.
Fri Nov 02, 2007 8:51 pm quote
Mine still visibly modulates at indicated 90mph, as the reflectors on the car in front of me showed. He would not for the life of him move aside so I could pass him
Sat Nov 03, 2007 6:31 pm quote
I had the same problem when installing the Diamond Star modulator on another bike. I flipped it around and it worked much better. That's why I decided to put this one where it could "see" the sunlight very easily!
As far as actual mounting positions, that's really up to you. I chose a bit of a complicated place for this particular install. I've seen people put the sensors at the mirror boot, in the handlebar cover etc.
Cheers!
~Josh
2007 Vespa GTS 250
Wed Nov 28, 2007 7:23 pm quote
I put mine in the right side mirror boot. A few minutes w/ the soldering iron melted the perfect sized hole.
I'm going to paint the nut black, or remove it altogether.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.2701s ][ Queries: 25 (0.0368s) ][ Debug on ]
