How To: Cut Down a Windscreen
Post Reply    Forum -> Modern Vespa Wiki
NOTE: This topic has a wiki article associated with it. You may view it here.
GTS250 GTS300 MP3 500
Tue Jun 03, 2008 6:10 pm quote
Created article How To: Cut Down a Windscreen
(This message was automatically generated)
2020 MP3 Sport 500 HPE ABS ASR
Thu Jan 08, 2009 4:17 pm quote
I used these instructions to cut down a tall Fabbri windscreen. Unfortunately, the Fabbri seems to be made of a more brittle material than the OE screen. I could not sustain a cut with my saber saw without the screen cracking and splitting. Having already trashed the screen, I tried different saw blades, all with the same result (including one that said it was for cutting plastic).
What ultimately worked very well was a Dremel tool with a diamond cutoff disk. No vibration, no splitting.
GT200 - Black
Thu Mar 12, 2009 4:59 am quote
I recently lowered the height of my FACO tall windshield. I took it to a glass shop but they said it was plexiglas and could not guarantee a cut that would not crack the shield.
So, not to be denied, I did the job myself using a Dremel tool with a standard cut-off wheel. It took 2 disks to get the job done, but it worked just fine.
Wed Aug 12, 2009 8:32 am quote
does anyone have pictures of what the final product looked like? I am kind of scared of cutting down my windscreen after it cost so much.
GT200 - Black
Wed Aug 12, 2009 9:27 am quote
I will take a picture tonight when I get home and sent it to you. If you have a cell #, that would be easier.
Ron
Vespa 300 GTS Super
Wed Jun 25, 2014 12:03 pm quote
Dremel Rotary tool instead of a jigsaw?
Does anyone think one of the cutting tools for a Dremel would cut "better" or easier? If so, which tool? (has anyone actually used one for this purpose?)
Wed Jun 25, 2014 12:32 pm quote
A dealer I used to use until he got out from under Piaggio always advocated a Dremel - but it used to take his lads ages to cut down a screen, as the Dremel had to be on the lowest speed so as not to melt the plastic, and they had to be very careful not to slip and scratch the screen. I recommend using a jigsaw - less chance of slippage, you just have to make sure the screen is very well supported.
2007 GT200, 2008 Yamaha C3
Sun Mar 20, 2016 3:28 pm quote
I use a 4" angle grinder with a metal blade to cut the bulk of the windshield. I then finish it off with a belt sander and hand sanding working up to 220 grit. Most of these windshields are acrylic. The serrations from even a fine tooth jigsaw are prone to causing cracks. I usually do it with the windshield still on the bike. I cover the scooter with an old bed sheet.
Primavera 50 4TK 4V
Wed Apr 27, 2016 10:30 am quote
Thanks for all the info on here! It made me feel confident to cut my own screen down too cos vision in the rain, at night, was next to nothing. Argh!
With my 5'6" I took off 5 inches from the top, using a simple hand fret saw and I think it turned out great.
Wed Apr 27, 2016 6:18 pm quote
Excellent result - well done.
2013 Vespa LX 150
Sat Mar 25, 2017 9:12 am quote
I don't like windscreens! But I acknowledge that they keep you warm and help with speed.
After unsuccessfully trying to sell the ridiculously tall screen that came with my LX 150 I decided to cut it down, only because it is wide and covers my hands.
I read the wiki article and followed the tips provided - blue tap to prevent scratching, very fine toothed metal blade instead of plexi blade, don't overheat or will melt and stick back together or get messy, use a cardboard template to draw out the cuts.
I used a small jigsaw and cut off about 12"'. I would have gone shorter but the mounting hardware limited me to that height.
Really emphasize NO plexiglass or plastic blade, this blade is too harsh and only wants to cut straight. The fine metal blade cut so smooth and allowed curving. I also used a water squirt bottle to keep the blade and plastic from overheating.
And then finished off the sharp edges with a palm sander.
Sat Mar 25, 2017 10:14 am quote
Well done.
Stella 2005/ Vespa gtv 250
Fri Mar 31, 2017 4:21 pm quote
Kinda low?
2013 Vespa LX 150
Sun Apr 02, 2017 6:18 am quote
That's the point
Sun Apr 02, 2017 7:05 am quote
Think I prefer a little higher! Sorry
Sun Mar 18, 2018 4:53 pm quote
Thanks for the instructions! I successfully removed a few inches from mine today, so now I'm back to an unobstructed view.
It's still a little cold (0C or 32F), which I was worried might make the plastic brittle and more prone to cracking. But it turned out to not be an issue.
I cut the windshield while installed on the bike. Used a reinforced Dremel cutting wheel at about 2/3 of max rpm. Then finished up with some sanding on 150 grit and 220 grit.
Now that I have a windshield, I'm going to get back in the saddle a few weeks earlier than I would have otherwise!
Sun Mar 18, 2018 5:21 pm quote
Nice
Fri Apr 06, 2018 4:58 pm quote
. I also am interested in cutting mine down. But also worried
Sat Apr 07, 2018 5:03 am quote
I started out with the biggest windshield you can get. It was on the scooter when I bought it. Kind of made the scooter look like the Popemobile.
2013 GTS300ie
Sat Jun 30, 2018 6:04 pm quote
I was going to ask why you didn't just buy the OEM mid-sized screen to start with, but then I noticed you said it came with the scoot...?
I do notice it is NOT in the Vespa catalogue, but it is available...
Missouri Loves Company Rally   vespa scooterwest scooter west Motorsport Scooters   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.2056s ][ Queries: 25 (0.0476s) ][ Debug on ]
