Trouble with the clock on an ET4
ET4
Fri Nov 25, 2005 2:42 pm quote
The clock on my 2001 ET4 has been running slow. I adjust the time and the next day it's off by about 11 hours. I've adjusted it about 3 times and it happens again. Is it the clock that's malfunctioning or the battery is starting to die?? BTW the scooter starts fine and runs fine.
Fri Nov 25, 2005 4:02 pm quote
Digital Clock
The digital clock runs from a small dry cell battery (which last about 2 years) accessible by lifting the entire instrument panel. Found this on page 29 in my owners manual 2005 ET4.
Tim
ET4
Sat Nov 26, 2005 2:50 pm quote
Or you can skip that altogether and install a digital tachometer there instead. At least that's what I would do.
Sun Nov 27, 2005 1:35 pm quote
Even with the manual, adjusting the clock on my ET4 is still hit or miss. If I get it wrong, the next day I just try again. In any case, mine has never been all that accurate...off by a few minutes in just a few days.
It's like trying to remember how to adjust for daylight savings time on your digital watch: You don't do it often enough to remember how to do it without the instructions. And you don't remember where you put the instructions. So you just play around with it until you get the job done.
01 ET2 - 01 ET4 -- 05 GT200L / 05 PX150 / 1986? Honda CH150 Deluxe.
Sun Nov 27, 2005 8:34 pm quote
Clock Time
My clock on my 05 GT has been very accurate, I would like to add some additional technical goodies on it, maybe some extra lights, and will look into making some one off custom leg shield deflectors soon.
Mon Nov 28, 2005 11:30 pm quote
the clock is run from a tiny little dry cell batt.
the vibration from just taking your bike off the stand can bounce the batt. in there and cause the time to go all wonky.
seriously, you're on a vespa... does it even really matter what time it is?
best,
-greasy
Cross Egypt Challenge - A 2400km ride throughout Egypt   vespa scooterwest scooter west Motorsport Scooters   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.3599s ][ Queries: 23 (0.0433s) ][ Debug on ]
