MichaelR wrote:
As you look at the clock there is a black oval button to the right with two bumps on it, one above the other. Consider the top bump "A" and the bottom bump "B". Press the "A" button to display month, day, and seconds besides hours and minutes. To adjust the above functions press the "B" button.
You can set the clock to flash between the date and time but I have found that sort of useless and just keep mine set on the time only. Be sure that when you are through adjusting the time that the colon between the hour and minute is flashing or the time will remain frozen.
The clock runs on it's own battery, not the scooter main battery, and has about a 2 year life span. Changing the battery means taking the headset apart and it is quite a pain to do. Good luck.
Translation..........
Get a watch
SDG
PS. Yes, exactly what MichaelR said
