carb trouble
ET4 2002, 3,100 miles
Fri Feb 13, 2009 7:38 pm quote
My ET4 has been sitting for 6 months, and the carb is gummed up (I guess). It starts perfectly, but won't rev up without shutting down. It runs well at idle. I filled the tank with gas, and I've let run for quite some time at idle, cranked it up slowly many many times. Turned it off, and cranked the handle many many times. Nothing improves the problem. I've looked in the manual to see where the carb is located, and I can't even figure that out. I assume if I can find the carb and squirt some antigunk liquid of somekind into it, that might clean it out and get it running.
I have no Vespa dealer nearby, and I of course can't run it.
Any suggestions?
'05 Vespa Granturismo
Fri Feb 13, 2009 8:36 pm quote
Sounds as though the main jet thr carburetor may be plugged.
MV Saint
Haud yer wheesh't if ye cannae be nice
Sat Feb 14, 2009 5:11 am quote
Hi mate, Though it sounds key related, i.e. scooter will not rev above 2000 rpms. Your carb is located under your pet carrier. There might be a small black rubber cover over it. I will try and find a picture for you.
Have a read here http://www.modernvespa.com/forum/topic24380.html
Cheers
Missouri Loves Company Rally   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.2339s ][ Queries: 23 (0.0506s) ][ Debug on ]
