Adjusting Stock Mirrors on GTS 250/300
Post Reply    Forum -> Modern Vespa Wiki
NOTE: This topic has a wiki article associated with it. You may view it here.
Size of a Chaffinch
PX 125 "The Bruise" (SOLD)
Mon Apr 06, 2009 9:19 am quote
Created article Adjusting Stock Mirrors on GTS 250/300
(This message was automatically generated)
GTS 300, etc.
Tue Jun 09, 2009 1:43 pm quote
What you really need:
17 mm open end wrench (spanner). Never do this with pliers!
2.5 mm allen key
How you really do it:
Remove the small allen bolt which holds the plastic cover.
Slide the plastic cover up the mirror arm.
Loosen the 17 mm lock nut, if necessary.
Position the mirror where you want it and tighten the lock nut.
If the lock nut does not hold the mirror firmly in place, do the following
Unscrew the mirror and remove it from the headset.
Clean and lubricate the threads.
Screw back into the headset and tighten the lock nut.
Replace the cover.
Roland
Missouri Loves Company Rally   Vespa Wasp Pin Badges   Cool Ass scooter seat cover
[ Time: 0.2681s ][ Queries: 23 (0.0839s) ][ Debug on ]
