How many Vespa dealers actually have the the equipment to do spin balancing? My local Yamaha dealer use to do spin balancing of my GT200 tires but new management won't allow them to do so anymore. Other then the BMW Vespa Dealers I haven't seen one with a true spin balancer.
1962 Lambretta TV175, 2001 ET4, 1972 Honda CB350 1969 Honda CL350
Posts: 327 Location: Folsom, CA |
I'm interested in this as well. I can mount the tires but can't get them balanced as well as I would like.
The Eugene dealer sends them out to get balanced, too. I'm trying to find out.
Hey 666, do you need to lube the tire before mounting it? I never have on a bike, is it any dif for a scoot? |
2005 Vespa GT 200
Posts: 1007 Location: Near Tyler, Texas |
My independent mechanic wets the tire before mounting it, and also has a spin balance, but apparently can't tighten it down on the machine's shaft properly, so he spins it by hand, and it works fine. He said the Honda dealer has a computer spin balancing machine that would work, too, but told me that 12" tires aren't that sensitive to balancing as larger tires. Anyway, I have no issues with vibration, etc., with either of my new Michelin Sports SC tires.
davet wrote: The Eugene dealer sends them out to get balanced, too. I'm trying to find out. Hey 666, do you need to lube the tire before mounting it? I never have on a bike, is it any dif for a scoot? |
Look at all the weights that are on the rim when you get a new scooter. They do need to spin ballanced. My front tire on My GTS need spin ballanced now. I deside not to use stock tires right off the bat and am using Pilot City
DIY (I'm so disapointed; I'm really shopping for one)
http://www.webbikeworld.com/motorcycle-wheels/balancer/ Stick on weights on eBay, get the smallest grams per unit you can find. Your local CycleGear? |
ritchj wrote: DIY (I'm so disappointed; I'm really shopping for one) http://www.webbikeworld.com/motorcycle-wheels/balancer/ Stick on weights on eBay, get the smallest grams per unit you can find. Your local CycleGear? |
The original Sava tires on the GTS will surely need balancing. They've never been good tires. Better brands won't need to be balanced as much. You can usually get away with not balancing a new conti or michelin tire.
Posts: 14691 Location: The state of insanity, SoCal |
Motorsport Scooters wrote: The original Sava tires on the GTS will surely need balancing. They've never been good tires. Better brands won't need to be balanced as much. You can usually get away with not balancing a new conti or michelin tire. best, -greasy |
