Will a GTS 250 rear rack fit a GT 200
'05 GT200, '07 GT60
Sat May 09, 2009 7:36 pm quote
Question is - will a GTS rear rack fit the GT 200 after you remove the stock rear rack. Liking the side bars for my passenger. Any experienced members out there?
GTS250 GTS300 MP3 500
Sat May 09, 2009 9:02 pm quote
Yes. Absolutely. You'll need the rack and the black plastic base. The GTS seat is optional, you could just as easily keep the GT seat.
'05 GT200, '07 GT60
Sat May 09, 2009 9:11 pm quote
Pardon me for being dense but is the black plastic base to provide coverage for the parts that are exposed when the GT rack is removed. Also - can you get that as a part from a dealer as a replacement part and if so what is it called. Plastic Base thingy?
GT200, Honda GB500, Honda CB400, Honda C70 Passport, 1999 Harley Dyna, 2002 Suzuki SV650s
Sat May 09, 2009 9:25 pm quote
Yep, or you can get one from a widow overhere after somebody hits a post
Sat May 09, 2009 9:33 pm quote
Yep. It's to cover the innards. I would imagine a dealer should be able to order it, but I don't have a part number.
'05 GT200, '07 GT60
Sat May 09, 2009 9:57 pm quote
So then the question is - does anyone have one of these for sale - I will post on the for sale / wanted.
Thanks for the help.[/img]
chassis cover
2010 GTS 300 Super, '07 LX 150
Thu May 14, 2009 7:52 pm quote
GTS Rack doesn't line up with GT holes
I finally ordered the Cuppini GTS rack & rear tank cover to do the rack conversion on my GT. The problem is the rack doesn't line up with the rear holes and the brack doesn't look like the correct angle. Take a look:
What's up with this? (And yeah, I know the marks from the old rack don't look so good, but that's a whole other problem.) Has anyone tried this specific rack?
I'll also post the un-notched seat to show the gap you get before the seat is cut down to go over the side bars.
Thu May 14, 2009 8:40 pm quote
Guys, guys, you dont have to do all of this! Just switch the name plates on your 200 with a 250 name plate and everything will work. Or you can saw the back half off of a 250 and then.............
'05 GT200, '07 GT60
Thu May 14, 2009 9:19 pm quote
Is that bugger just bent out of shape from shipping or rough handling in the warehouse?
Wed May 27, 2009 7:22 pm quote
I'm happy to report that the replacement Cuppini rack from Scooter Parts finally worked. The first one was bent at the rear bracket. I cut the seat notch with a dremel disk, then smoothed it to look like the original molding with the sander attachment.
Here's the links. I hard trouble finding that tank cover part initially:
Cuppini GTS Rack
http://www.scooterpartsdirect.com/cat.php?prod_id=2560&cat_id=4&subcat_id=467&men_id=1
Rear Tank Cover
http://www.scooterpartsdirect.com/cat.php?prod_id=2907&cat_id=4&subcat_id=467&men_id=1
Here's how it came out:
Land of 10,000 Scoots Rally   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.1642s ][ Queries: 25 (0.0367s) ][ Debug on ]
