Rightio ive got the loom through and working kind of. Im completely confused about the hand switches/bulbs.
Brake light works fine
The wires coming up from the loom to headset are white black green yellow
Now I know
Yellow- 12v feed for lights
Green - Kill
White - Horn
Black - Tail Light
Now these are tested and all work.
Now the confusing bit is the headlight switch, i have this kind of switch
http://www.scooterhelp.com/manuals/VSX1T.manual/008.jpg
Now the switch has yellow, grey, white, brown, purple wires (minus the horn wires)
Now the yellow is the 12v feed (or is it?)but other than that im completely clueless. Cant find a wiring diagram and its 12v cdi but old switch.
Ive tried tested different ones, ive obviously earthed the light bulb holder, tested all bulbs and all work. but i thought I was getting somewhere as the grey wire keeps the side lights on when the toggle switch is switched both ways and turns them off when at position zero, but if you plug in what i think is high/low it doesnt work
