I've searched for clearance issues with the Sito Plus exhaust. Most indicated there would be a problem with 8" wheels, or riding two up on left turns. I've installed a Sito Plus on my Rally 200, and in addition to hitting the ground on left turns, it also interferes with the center stand retracting. The rubber boot and the stand leg both hang up on the seam/lip of the exhaust. I've tried grinding some of the lip away, but don't want to get too carried away in case it's a welded seam.
The stand I'm using is #91047 from Scooterworks. After a few cycles of the stand, the exhaust has cut through the side of the rubber boot so the boot now falls off. Is there any option other than a side stand and keeping the Sito Plus? I measured the stands on my VBB and P-200 and they seem to be about 1/2-3/4" wider than the new one on the Rally. Would bending the new one slightly work? Or, are there other stands that are wider to begin with? The new one is also much harder to find with your foot when it's stowed and trying to park.
