P200 owners - drop your cowls and let me see it!
1980 P200e, 1956 ACMA, 1979 P200e, 1974 Ciao
Sat Aug 01, 2009 4:36 am quote
Hiya,
I bought my 1980 P200e a few months ago. It's got a 12v electrical system, but it's a real mess. The battery is literally held in with a bungee and some duct tape. The bracket to mount the spare tire is completely missing.
The diagrams I see in the manuals are nice, but I'd love to see what other people's battery and wiring look like, so I know what I should be shooting for as I clean mine up.
So, if you've got a moment, please take a picture of your P200e battery and wiring under the left cowl, and let me see!
Thanks so much!
Mike
Ugly mess
Moderibbit
Sat Aug 01, 2009 4:56 am quote
Hm I'll try to get a picture a little later. There are a few funky looking things there, but the main thing is there is a battery tray which bolts onto the bolts in your picture. The battery actually sits in that tray and is held in place by a band of rubber, or "rubber band" if you will
nothing at all
Sat Aug 01, 2009 5:31 am quote
trying to locate more
the close up shows an inline switch on the positive lead, this is NOT necessary.
1978 P200E, 1963 GS 160
Sat Aug 01, 2009 5:52 am quote
What a mess. I'll try to post one later today.
eta: Here's an old one. I'll try to get a better angle later.
Moderibbit
Sat Aug 01, 2009 6:46 am quote
looks like they got you covered Your fuse setup is weird as well... the fuse should be of the manner depicted in this thread:
http://www.modernvespa.com/forum/topic49704
That oblong fuse fits inside a little cylindrical fuse holder off to the side of the wiring there. You can kind of see it in Jimmy's pic - there are two red wires running off to the left in the foreground. Right behind them is another set of red wires hugging the left side of the battery tray. Those wires go into the white fuse-holder I've described. He has some yellow electrical tape or something on the bottom of the fuse holder, if that helps you identify the part to which I am referring
However, your jerry-rigged fuse is not a huge problem at the moment. If it works it works. I'd worry more about securing the battery better
nothing at all
Sat Aug 01, 2009 6:54 am quote
i don't use theold porcelin fuses any more
i now run a blade fuse set up
the blade fuse arrangment in the top picis incorrect
your local auto store should have plenty of bladefuse holders
weaterproof and better imho
radio shack has em too
Moderibbit
Sat Aug 01, 2009 6:57 am quote
interesting, thanks for the info Jimmy
nothing at all
Sat Aug 01, 2009 7:06 am quote
ifyoumake the swap it is good tokeep the old twist holder for resell
some weirdo may want to put it back on
so he can have fun back twisting the holder before twisting together
oh yea, thats after he spent all day trying to locate the lame ole porcy fuses
i have a couple laying around i can show my grandkids
in all honest the old set up is'nt bad, i just simply like the blade type
New PX 150 2006, Super 150 1976, Honda Vario 2006
Sat Aug 01, 2009 5:25 pm quote
Here my New PX 2006
Sat Aug 01, 2009 7:05 pm quote
Thanks for the pics
Thanks for the pics, gang. I cleaned up my battery and wiring situation significantly today. Someone, in the past, had put a fuse on the ground lead. I cut that out. I removed the original in-line fuse, since I couldn't find any fuses to replace the one that had blown in it. It now has a modern "blade" fuse socket on the positive leads.
It appears my battery is too tall. Someone must have replaced the old one with one that's too tall. It covers up the two mounting bolts for the spare tire.
Quick question... would the spare just bolt onto those two bolts at the top of the battery mount, or does it also secure down below? I see a bolt below and at the center of my battery. Does the spare bolt on in two places, or three?
Thanks!
Mike
01 ET2 - 01 ET4 -- 05 GT200L / 05 PX150 / 1986? Honda CH150 Deluxe.
Sat Aug 01, 2009 7:07 pm quote
How easy is it to remove the cowls with the side gaurds still on?
GS 160 /4
Sat Aug 01, 2009 7:17 pm quote
The hole under the battery receives the long bolt on the spare tire cover.
What? You don't have a spare tire cover?
Che vergogna.
- Eric
nothing at all
Sat Aug 01, 2009 7:26 pm quote
i don't run a cover on my p
two bolts at the top are secure enough plus i don't like the look
GS 160 /4
Sat Aug 01, 2009 7:29 pm quote
That's 'cause those plastic P covers look cheap.
- Eric
nothing at all
Sat Aug 01, 2009 7:50 pm quote
- Eric
you are oh so right
PX200E
Sun Aug 02, 2009 3:52 am quote
Undo the rear 13mm nut and the guard swings up and forwards.
Just another 30 seconds of work
Same guard in powdercote
Sun Aug 02, 2009 5:06 am quote
Great, thanks for the updates gang! It would appear I'm lacking the cheap plastic cover for the lower part of the spare.
I don't mind much. I don't carry a spare. The P is so back heavy to begin with! I've got AAA to get me home, if I blow a tire on my work commute.
Sun Aug 02, 2009 9:41 am quote
Just loose the rear nut (13 mm), and pull up the rear crash bar.
Done!!
Sun Aug 02, 2009 10:25 am quote
nothing at all
Sun Aug 02, 2009 10:35 am quote
i cant beleive out of all the p series owners here only a couple of us have stepped up and really showed pics of the wiring and battery
come on guys and gals, read the post and pull your cowls and show us
or are you lazy or chicken or too ashamed of the condition that the battery and wiring is in.
Sun Aug 02, 2009 10:53 am quote
Here is a battery tray and strap from ScooterWorks....
http://www.scooterworks.com/Battery_Tray_P_Series_P539C446.cfm
http://www.scooterworks.com/Strap_Battery_P1632C446.cfm
Moderibbit
Sun Aug 02, 2009 11:59 am quote
I can still get a pic up if the OP wants... I just figured if you've seen one good setup then you've seen them all. And yours, Jimmy, is more than good
Sun Aug 02, 2009 12:14 pm quote
I'm all set, folks. What I lack is the strap from the post above, and a battery of the correct size to use said strap! lol.
I'll add both to my xmas list For bonus points, I'll look for the lower plastic cover for the spare, too. As I said, I wouldn't use it, but it would be nice to have with the bike.
Thanks,
Mike
nothing at all
Sun Aug 02, 2009 6:49 pm quote
your mc shop will have the battery
there's two sizes that fit that tray
get the smaller one, the bigger one is thicker and the wheel cover wont fit
Mon Aug 03, 2009 12:53 am quote
my battery is a YUASA---Yumicron -----YB9-B
or failing that the dimensions are give or take a millimetre or two
height-140mm
depth-73or75mm
width-134mm
best of luck
Mon Aug 03, 2009 9:10 pm quote
it
nothing at all
Tue Aug 04, 2009 7:09 am quote
joshzingzing wrote:
it
oooh lala
thats tight
Missouri Loves Company Rally   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.1627s ][ Queries: 27 (0.0467s) ][ Debug on ]
