FAQ: How do I Search Modern Vespa?
Post Reply    Forum -> Modern Vespa Wiki
NOTE: This topic has a wiki article associated with it. You may view it here.
Wed Sep 09, 2009 6:31 am quote
Created article FAQ: How do I Search Modern Vespa?
(This message was automatically generated)
1998 Piaggio Liberty 125 (Pre/Non Leader)
Tue Aug 13, 2013 10:14 am quote
wiki moderator or member with more than 100 posts wanted...
Please can someone edit the last sentence, in the last paragraph of:
To read:
Now try to Google "custom paint job" modernvespa.com
The first hit is Modern Vespa : Fuoco Custom Paint Job
Removing "site:www."
All will be revealed when tried.
This has the blessing of Jess.
Cheers
Žich
Tue Aug 13, 2013 10:45 am quote
Done.
Fri Aug 16, 2013 2:36 am quote
FAQ: How do I Search Modern Vespa? - With Google - Reviseted
At the risk of awaking the wrath of a Petty Tyrant and a Moderaptor; I need to revisit searching MV with google. I can't put MV readers through 50 more postings to be able to do this myself - but in my quest for instant search gratification here we go...
Below are some graphics which explain better than words how to search. The example posting was less than 24 hours old; So googlebot difference indexing works very quickly (1 - 23 hrs).
Simple, one or two word search terms will usually give you the broadest results. Start with short search terms, then refine your results by adding more words.
Put quotation marks around words "Word1 Word2" to search for an exact phrase in an exact order. Keep in mind that searching with quotes might exclude relevant results.
The word(s) you enter must be followed by site:modernvespa.com with no hint of "www"
You will then turn google search into an MV only environment. ie: The only results you will get will be from MV! Marvelous.
PS: If you click the Images button... Tis a joy to behold.
Žich
Fri Aug 16, 2013 3:25 am quote
Re: FAQ: How do I Search Modern Vespa? - With Google - Revis
So you didn't mean:
but:
OK, now done. No wrath involved.
I've removed the comment about 'the first hit will be' - as that's subject to daily change...
Land of 10,000 Scoots Rally   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1383s ][ Queries: 23 (0.0250s) ][ Debug on ]
