Lets talk about P150S!
Post Reply    Forum -> Not-So-Modern 12345Next
Yamaha MIO :P
Thu Oct 01, 2009 11:59 pm quote
few here (if not none) ever talk about P150S,
From Scooter help
S p e c s: VBXIT
1978 - 1984
engine: single cylinder, air cooled 2-stroke
induction: disc valve
bore: 57.8 mm
stroke: 57 mm
cubic capacity: 149 cc
compression ratio: 8.2: 1
bhp at rpm: 7.5 @ 5750
lubrication: 2%(USA autolobe)
transmission: 4 speed constant mesh
1st gear: 14.47: 1
2nd gear: 10.28: 1
3rd gear: 7.31: 1
4th gear: 5.36: 1
clutch: wet - multiplate
carburetor: Dell'Orto SI 20/20 D
venturi size: 20 mm
main jet: 116/100
slow running jet: 160/100
throttle valve: 6823.01
mixer tube: BE 3
atomiser: 280/100
starter jet: 60/100
ignition: contact breaker & coil
ignition timing: 21 deg. BTDC
voltage: 12 volt
similar to PX, but fitted with VBX motor, 8' tyre
many claim its one of the fastest vespa, on a stock part it could reach 100km/h (many of it take part on a local racing competion)
Indonesian P150S strada variant
(the original headset is a semi rectangular head set)
change the head set with round PX head set
Strada front
VBX motor P150S
Original paint and stock parts STRADA year 87
mod strada
Strada Racing
P150S
and the other variant is the SERA
i dont have the pic now (not many sera around this day, i'll try to take a pic of it if im came across one someday),
the differences is on the headset
SERA is fitted with rectangular headlamp
anyone wants to add something?
like this
SERA Badge
Fri Oct 02, 2009 3:43 am quote
So, it uses the standard length kickstart lever ... but sits 2" shorter to the ground. Doesn't the kickstart lever rub on the ground a bunch?
Yamaha MIO :P
Fri Oct 02, 2009 3:56 am quote
yes, maybe... but no complain from Strada owner.
but many Strada owner switch the 8" tyre to the 10" tyre for better handling
and for cosmetic purposes (it makes the bike look bigger)
the uniqueness of PS is the Front fork. notice the Pre PX front fork
Fri Oct 02, 2009 6:56 am quote
Yeah...8inch tire to me is no good...unless you don't plan on going over 40mph.
Fri Oct 02, 2009 11:03 am quote
I love the 8in wheels. Everything else is practically a motorcycle.
I would totally rock a P150S dead stock on the outside right down to the 8 in wheels.
Fri Oct 02, 2009 11:16 am quote
i thought those things had glove boxes on the cowls?
'99 PX200
Fri Oct 02, 2009 1:24 pm quote
Wouldn't it sit 1" lower Eric?
A.Pedant
nothing at all
Fri Oct 02, 2009 4:09 pm quote
i dont care how low it would sit
tilt it and kick it
i'm with patrick on this one, he did make me a princess today, i am very honored
8 inch makes for a quicker equation to your kit
it's in the math
'78 Super 150 Mk II ported DR177, banded clutch, ASC Big Bore
Fri Oct 02, 2009 4:38 pm quote
I routinely go about 47 mph on my 8" shod Super 150 with a 3 port engine (which, if memory serves was the precursor to the 150S) and top out at around 51mph.
Naturally the contact patch is slightly smaller, affecting overall traction, and bearings have to work harder given more revolutions of the wheel for each mph -- plus more tire wear-- compared to 10" wheels.
The bigger rims would allow a higher top end (assuming there was enough power to get there) but slightly slower acceleration off the mark.
The 8"s do allow for a very quick and responsive initial turn in; however, the down side is getting blown around a lot in a crosswind (which I often encounter during my commute) and any crack or line in the pavement will really grab the tire...
I'm planning to try some 10" wheels for next season, upgrading to a 20/20 carb from a 20/15 for a bit more oomph. I'm debating a bolt on Poloni 177 kit, too, since I have a leak at the head...
It depends on my wife's patience, I suppose
Yamaha MIO :P
Fri Oct 02, 2009 7:29 pm quote
yes! you are absolutely right! there is also PS with glove box on the cowl.
and also PS without turn signal, tomorow i'll try to take a pic of it
Yamaha MIO :P
Fri Oct 02, 2009 7:53 pm quote
SERA P150S
without turn signal, no glove box. which located on the left cowl. square headset
front spare tire, switched the seat to spartan (P200XE) seat
Fri Oct 02, 2009 9:36 pm quote
robbyrivai wrote:
SERA P150S
That's it! That's the bike I want! Not sure where I'd keep it...
I use to draft trucks on the freeway on my vbb. After it pulled you up to speed you could hold it for several miles.
Yamaha MIO :P
Fri Oct 02, 2009 10:14 pm quote
oopsclunkthud wrote:
robbyrivai wrote:
SERA P150S
Thats scarry mate! , I'm more of slow rider person
and here in Jakarta 2-3 wheeler are not allowed to use the freeway
gt200,px125,gp150,gp200
Sat Oct 03, 2009 1:13 am quote
i like these
we have a guy in our club has square headlight version
trouble is headlight is cracked and can't find one in uk or ebay
anyone with info of dealer with stock would be great
it is still on 8" wheels , no indicators,and toolbox in l/h panel
nothing at all
Sat Oct 03, 2009 5:34 am quote
i have never seen a factory p series without indicators in my whole life
very cool robby
Yamaha MIO :P
Sat Oct 03, 2009 6:29 am quote
very cool robby
next i'll post a bigger pic jimmy
Sat Oct 03, 2009 4:10 pm quote
very cool robby
Here's a no indicator P150X I restored but it had the round headlight and 10 in wheels. Not as cool as the S.
Blue is leaving the garage
Sadly it's looking for a new frame now, after a car turned left...
PX200E X 2
Sat Oct 03, 2009 4:36 pm quote
very nice!
nothing at all
Sun Oct 04, 2009 5:52 am quote
that is really nice patrick
Yamaha MIO :P
Sun Oct 04, 2009 8:23 pm quote
blackie wrote:
i like these
hard to find here as well...
Sun Oct 04, 2009 8:59 pm quote
that is the smoothest brick i ever saw.
nothing at all
Mon Oct 05, 2009 5:26 am quote
well said small
Mon Oct 05, 2009 5:33 am quote
jimmyb865 wrote:
well said small
jimmy, i figured that you would appreciate that.
Yamaha MIO :P
Tue Oct 20, 2009 10:28 am quote
a friends newly rebuild PS Strada
nothing at all
Tue Oct 20, 2009 7:24 pm quote
robby, why are the rear indicators diff than the ones on the strada in the top of post, the ones that are angled???????????
Yamaha MIO :P
Tue Oct 20, 2009 8:34 pm quote
there is 2 kind rear indicator, the straight and the angled,
mostly the older version fit with straight indicator, the angled is for the newer version. However the stock is actually the angled version, but the stock is in poor shape so the owner fit with the newer version rear indicator that is actually for the New PX. (actually its a rip off rear indicator, its taiwan made, cheap $10.)
ET4
Wed Jun 23, 2010 9:09 pm quote
Hello.
Will the rectangle headlight of the T5 fit the p150s? I was wondering because I might get a P150s one of this days.
not-so-normal
Fri Jun 25, 2010 12:13 am quote
redshirt wrote:
Hello.
nope
T5 have different fork with single large pinch bolt... maybe you need a kit to make it fit
p 150strada
Tue Mar 08, 2011 7:54 am quote
this is a very nice thread.
in indonesia is so many PS,,like sera,strada,strada 2,sera 2.etc
my topspeed is 110 km/h..with 8"tyres
Tue Mar 08, 2011 8:56 am quote
Lovely scoots there. I'd love one of those square headlights for my px
T5s
Tue Mar 08, 2011 9:00 am quote
zombie stitches
i love the angled rear indicator lights
Severl Scooters
Sun Jul 03, 2011 8:02 am quote
I just got mine, This Bike was owned by the ScooterSuperStore Owner and he had a few of them Restored but did not complete the build. It cames with a Fully painted Body with all the panels, new cables, new tires and harness. All of it was new but the Headlamp. The headlamp was glued together. It cames with a new LML motor that was still in the box which ive installed now. I got everything for $1400.
Now im Running into a problem i need to get a replacement Headlamp and i have no Clue where to look for one, ive check everywhere.
Also how do you know which one you have as i see above there are 2 different models? The Shop upgraded it to 10inch wheels prior to me getting the bike and they only sold the bikes because the owner died and they closed there store down and all his personal collection was sold. I baught a VNB, 50 special Small frame,
Does anyone know of a shop that sells the headlamps or like Ebay or anywhere like that? Does anyone know if this Wire Harness is the same as any other P bike?
p200e,px 200,px150e,px125e
Mon Jul 04, 2011 3:00 am quote
i dont have a 150s
but i am thinking about selling my px150 original 1985 model with only 70km never been registered complete with books, tool kit and user instruction stickers
the only reason it has done 70 is that twicw a year i take it for a 5km run
whats it worth???
Primasarah
1979 P200E, 1977 Rally 200, 1974 Primavera
Mon Jul 04, 2011 8:03 am quote
carlo r wrote:
i dont have a 150s
whats it worth???
$1500-2200 in the US on a good day.
Mon Jul 04, 2011 10:58 pm quote
is that all for a brand new (odo 00070) 26 year old Italian scooter
Yamaha MIO :P
Thu Jul 14, 2011 10:23 pm quote
the headlamp Its plenty in my place in jakarta, i could help you find one. but i dont know a thing about shipping to your place
a not so normal vbb2 '64, a weirdo vbx '86 and a not so normal pts100 '82
Thu Jul 14, 2011 11:30 pm quote
robby check his headlamp, i believe it were sera version that came very boxy and had metal cast, kinna difficult to find for truth unlike the plastic handlebar top cover that were everywere
another reason why some of my friend ps150 going to the drop bar or naked excel handlebar and ekslusif II if they had money
Yamaha MIO :P
Thu Jul 14, 2011 11:45 pm quote
yes its a sera head lamp, Im pretty sure i can find one
Fri Jul 15, 2011 2:32 am quote
yups not that rare either in fact i am now trying to bargain my friend sera headset for $5 (wanna try to reshape it to be round) or better swap with my super trap head
Yamaha MIO :P
Fri Jul 15, 2011 2:54 am quote
yups not that rare either in fact i am now trying to bargain my friend sera headset for $5 (wanna try to reshape it to be round) or better swap with my super trap head [/quote]
why would you want to do that? better use PX head if you want to reshape it, cos PX head still plenty around, but PS Box headlight? i dont think u will find it as much as PX headlight... better yet why dont you use indian mad PX head?
just my two cent
Land of 10,000 Scoots Rally   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.3410s ][ Queries: 25 (0.0347s) ][ Debug on ]
