LX150 Complete EVAP System Removal
2007 lx150
Fri May 21, 2010 2:02 pm quote
I don't have enough posts to have permission to make a wiki, so I'm posting this here. If you want, you may move this into a wiki.
Here is how I removed my EVAP system. It was easy, and took about 30 minutes. I now run much happier, and don't have to worry about vapor-lock, or flooding my air-filter.
Proceed at your own risk. I'm not saying this is the best way, it was just the way I did it. I'm not responsible for you breaking your scooter.
You will need:
Metric wrenches or sockets
1 Small hose clamp
1 Set of plastic hose connectors
1 set of vacuum plugs
Zip-Ties
New Foam Paint Brush (to make the cover for the evap-hose [c] inlet on the carburettor).
Scissors
Evap Removal
Diagram of LX150 Anti-EVAP System
The orange letters (A,B,C,D) are used in my photos to identify hoses, and to give the reader a point of reference.
*Note. On my 2007 LX150, The Vacuum Fuel Tap (#6) does not connect to hose A as the above diagram shows.
Instead, the Manifold Hose (Connecting the front of the carburetor to the manifold) has two nipples on it.
• 1 Hose connected to the Cannister (#5) via the Safety Valve (#4).
• 1 Hose, connected to the Vacuum Fuel Tap (#6)
To remove any hoses or components from hoses (With the exception of Hose C from the Carbuerator [#1]) you will have to remove the metal clamps from the hoses. To remove the clamps:
1. Put a small flathead screwdriver under the end of the clamp
2. Gently hit the end of screwdriver with a hammer
3. Twist the screwdriver to pop open the clamps
• Remove the pet carrier.
• Remove the two bolts that hold the Canister (#5). * Ensure there are no other clamps or ties holding the canister or the attached hoses.
• Slide canister down and carefully move into engine compartment. *Be careful not to disconnect any hoses while moving the canister.
• Remove hose A from canister
• Remove hose B from canister
• The canister can now be discarded or saved for future use.
• Remove the two bolts holding the Roll-Over Valve (#3) in place.
• Move Roll-Over Valve down, and into engine compartment.
• Disconnect hose B from the Roll-Over Valve.
• Carefully pull hose B out of engine compartment and store for later steps.
• Disconnect hose C from Carburetor (#1). *This hose should pull straight out.
• Save hose C for later use.
• Disconnect Hose D from the Roll-Over Valve.
• Disconnect Hose A from the Manifold Hose.
• Hose A (with the Safety Valve (# 4) on it) can now be discarded or saved for future use.
• I used a foam brush to make a filter for the hole on the Carburetor where I removed hose C from. *I saw this filter idea on modernvespa.com I can’t take credit for it.
• Cut the brush as show.
• Gently remove, being careful not to damage the new square section of foam.
• Cut a 2-3 Inch section off of hose C.
• Put the foam on one end of the hose you just cut, attach it with a hose clamp, or tight zip-tie.
• I sprayed a touch of filter oil on my finger, and dabbed it on the foam to help protect the carburetor.
• Attach the new hose/filter combo onto the carburetor where hose C was removed from.
• Plug the nipple on the exhaust hose (which hose A was removed from) with a Vacuum cap.
• Secure the cap with a hose clamp for added security.
• Insert a connecter into the end of hose D.
• Cut a long section of hose B, and attach it to hose D via the connecter.
• In the event of an over-fill or a tip over, fuel will come through this hose.
• Secure the newly lengthened hose D to the frame and route the hose to a safe place for gasoline to drain.
• I simply followed the frame down and secured the hose with zip-ties.
• Here is hose D, If I overfill my tank. Gas simply pours out onto the ground. Not my air filter.
• Take a moment to enjoy your newly de-EVAP systemed engine compartment.
-Brtoney[/b]
'07 GTS-250ie - sold and gone
Sat May 22, 2010 10:56 am quote
Great to see so substantial a contribution from so new a member. Fine work indeed!
2007 lx150
Sat May 22, 2010 1:06 pm quote
Thanks.
I know by looking at the many, many, many, threads discussing the leader 150 evap, that it's very common. I felt that if I was getting frustrated reading all those threads people must be tired of re-typing the same info.
Plus, I'm 2.5 hrs away from a Vespa service shop. So without all the info you people put up, I would be without a properly running scooter. I wanted to help the community out.
Anyway, Thanks for your thanks.
-Brett
P200 PX150
Sat May 22, 2010 8:32 pm quote
Very nice!
vespa px210e
Sun May 23, 2010 12:01 pm quote
not being auto minded what does it do? cheers
Sun May 23, 2010 3:42 pm quote
Gets rid of the Evap Crap that you guys have to suffer on all new bikes.
2007 lx150
Sun May 23, 2010 3:53 pm quote
I had just pulled out my air filter and cleaned it, when a cheap gas pump overfilled my tank onto my air filter. Now I have to pull all that chrome off, and clean it again.
That was the last straw for my evap system.
lx 150 sky blue
Wed May 26, 2010 9:10 pm quote
Why?
I've had my LX 150 since Dec 2006, and the only problem I have had is the battery going dead. No cutting out, no loss of power going up or down hills (and that's all we have here outside Pittsburgh) no vapor lock no problems. I can never understand why people always want to disconnect the evap. I just don't get the whole "I don't need it around my parts" attitude. Then again I pay attention when I fill up my bike.
2007 lx150
Thu May 27, 2010 2:46 am quote
Re: Why?
I don't necessarily have a "i don't need it around my parts attitude", but it is a poorly designed system, that when combined with a malfunctioning gas pump, flooded my air filter with gas.
LX 150
Sat Jun 05, 2010 7:36 pm quote
Outstanding!!!
Your instructions are so easy to follow even I did it in an hour.
In Calif. there is pending legislation to emission check every 2 years all motorcycles over 200cc. This makes it perfect for an LX 150. This legislation appears every few years so maybe someday you may need those parts if you alter a larger bike..
2007 lx150
Tue Jun 08, 2010 12:53 am quote
Re: Outstanding!!!
I'm really glad that you found it useful. Thanks for your feedback! It's greatly appreciated.
2005 ET4
Tue Jun 08, 2010 8:01 am quote
Do you think this is pretty much the same as on the 2005 ET4?? I'm hoping since I would like to do something like this over the weekend.
GTS 250 i.e. "Silver Bullet"
Tue Jun 08, 2010 8:18 am quote
I would think it is almost exactly the same. The location of a few bits might be different, but for the most part it should be the same.
2007 lx150
Tue Jun 08, 2010 10:44 am quote
The lx and et4 both have the leader 150 engine. I'm pretty sure once you get in there everything will be almost exactly the same. Maybe a different color tube, or as the other poster said, a bolt in a slightly different spot.
PX, 1960 150, scrap heaps
Wed Jun 09, 2010 7:19 pm quote
Nice write up.
I left to components on the scoot and just disconnected the two main hoses. In part because I am lazy, and if someone wants to hook it back up in the future, it will be easy.
My first modern 150 had no troubles with the evap. The second scoot's evap has been annoying from day one. Guess I was luck the first time.
Vespa LX150
Mon Jul 19, 2010 4:56 pm quote
Re: LX150 Complete EVAP System Removal
Quick question - did you remove your roll-over valve? It appears so, but I didn't see that verbiage stated in your description.
Cheers,
ChimChim
Btw, I just removed the EVAP hose (C) and plugged the hose with a vacuum cap. I also attached a 3/16" ID fuel line to the carb and used your filter idea. Also, my 2009 LX 150 EVAP struture is very different than yours. My wife's ET4 mirrors your set-up.
Hugely excessive over-quote removed. jimc
Fly 150
Wed Jul 21, 2010 8:59 pm quote
Thanks for the great effort
That took a lot of time and effort to give us such great info on the evap problem - it printed out and added to my file.
Many thanks for the effort...I now feel safe to solve the problem should it arise.
2007 lx150
Sat Jul 24, 2010 3:05 pm quote
Cheers,
ChimChim
Yes, I took the roll-over valve off. I wasn't sure of it's condition, and It was only causing worry that it might fault and cause a pressure build-up in the tank.
If I knew it was like new, I would have left the valve in place.
Sorry for taking so long to get back to you!
2007 LX150 Dragon Red & 2009 H-D FLHRC
Wed Aug 18, 2010 3:21 pm quote
Great write up. Thanks for taking the time to post it.
2006 LX 150
Thu Mar 22, 2012 4:52 am quote
Took evap out a year ago
Been running awesome, just curious on what the maintenance is on the paint brush filter. I dabbed a little air filter oil on it about a year ago when I took out evap.
2007 lx150
Thu Mar 22, 2012 6:07 am quote
I rinsed and re-oiled mine the following spring...
09 190s taormina
Thu Mar 22, 2012 8:01 am quote
Foam not really needed, port is vent only. Factory piece for ROW is short elbow.
factory "Euro" carb hose elbow for evap disconnect
Sat Jul 06, 2013 11:02 pm quote
Maybe this is a stupid question, but is this mod needed on the new fuel injected vespas? What happens to gas overflow if the tank is filled too high on a 2013 LX150?
09 190s taormina
Sun Jul 07, 2013 6:19 am quote
Not needed. Doesn't stop people from doing it though.
Recommendation: until you have an issue (and you won't) leave it alone.
2x 2018 Piaggio Liberty S 150
Mon Mar 03, 2014 4:58 pm quote
Will probably do this mod on the '08 LX150 my wife just bought, but I have a question (technically 2). In the original post, the poster calls for:
Where does one get these? Do they come in different sizes, etc? Just want to make sure I have the right items at hand.
09 190s taormina
Tue Mar 04, 2014 11:44 am quote
Auto parts.
Yeah, different sizes, take the hose from fitting you want to plug to match.
Don't need the hose connector. And recommend leaving rollover valve in place. In event of crash steel body = sparks. Adding a fuel spill might not be pretty.
Tue Mar 04, 2014 1:11 pm quote
Then how would you lengthen "hose D" in order to route it down to the bottom of the frame?
Hmm, these instructions have everything removed from that valve, so... I'm not sure how to adjust the instructions to leave the valve. Heh.
ET4
Wed Nov 04, 2015 5:07 pm quote
2006 LX 150 i.e.
Fri Mar 02, 2018 10:54 am quote
tuttle762 wrote:
What's the link to this? What was it?
2006 LX 150 i.e.
Pictures not showing up
Everyone else can see the pictures?
2006 LX 150 i.e.
Fri Mar 02, 2018 10:58 am quote
Re: Outstanding!!!
Was this moved over to the wiki? I can't see the pictures on original post.
Vespa LX 50 2008 Rosso Dragon
Wed Aug 01, 2018 9:45 pm quote
Re: Pictures not showing up
I can see the pictures correctly. Do you still can't see them?
S 150
Sat Nov 16, 2019 9:52 am quote
I don’t see them either [/i
S 150
Sat Nov 16, 2019 9:53 am quote
Yeah I don’t see them either
Vespa ET4
Sun Jun 07, 2020 4:52 pm quote
Thank you for this post!
I just bought my 2001 Vespa ET4 150 this spring. It had less than 4k miles, and it was in great shape! Things were running well for my first several hundred miles until I started experiencing the "bogging down" at starts from red lights, etc. Also began to feel it even without starting out from a stop... to the point I had to pull over a couple times to let the engine work itself out.
I took it to a local scooter shop. They were very friendly, but they ultimately didn't know about the EVAP situation.
Thankfully, I found a YouTube video (I think about carburetor cleaning) mentioning "the EVAP mod..." which led me here. This tutorial, along with a much more stripped-down YouTube version, helped me remove the EVAP system in just under an hour. And, now... purrs like a kitten! Problem completely resolved.
A couple things I did differently than the above:
- I didn't take the vacuum hose completely off, but rather it cut it to about 3 inches. I then screwed in a large bolt into the hose to cap it. Just something I had lying around. I may buy a vacuum cap one day, but this works fine.
- I didn't have a foam brush, so I used whatever was around to cover the carburetor hose. In this case, my daughter had some thin foam "pre wrap" for gymnastics, and I used about 8 layers of this. Anything porous would work. (Also, I just cut short the hose that was originally connected... No need to buy a new hose.)
- Finally, I didn't have hose connector to extend the gas overflow tube. so I didn't extend it to the bottom of the frame. It's just tucked inside the plastic side cover. I may try to re-purpose the three-way connector to do this.
So... thanks again for original post. Fixed my engine issue. The whole project took less than an hour, and I didn't have to buy a single thing.
99 & 01 honda elite 50, 06 yamaha vino 125, 07 suzuki burgman 400 , 84 Aero 125, 05 Vespa LX 150, 2010 Honda Elite 110
Mon Jun 08, 2020 9:17 pm quote
Tutorial Video
Here's video how to on LX150
Click on video to take you to YouTube page and I have list what you need in description below the video
https://www.youtube.com/watch?v=g8fjAvKI6Ow
Land of 10,000 Scoots Rally   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.1795s ][ Queries: 27 (0.0461s) ][ Debug on ]
