ET4 125 Belt and Rollers Change
2003 ET4 125
Fri Mar 18, 2011 12:46 am quote
Hey Guys
Question
When changing the drive belt on my ET4 125, do I need to remove both the variator (driven pulley?)side and the other side. or can I just remove the variator side and replace the rollers at the same time?
Your Help Appreciated.
ignoblis
Scooter Pimp
------2001 Honda SH-50------
Fri Mar 18, 2011 1:01 am quote
Hi Ignoblis
If it operates the same as the ET2 (which I'm think it does) then you need to remove the drive belt cover, undo the variator nut and slide the variator off to get at the rollers, the belt will come away with the variator but will probably stay trapped in the groove of the faces of the rear driven pulley.
You can then grab the front face of the rear pulley and squeeze it shut to release the belt (try squeezing and twisting slightly at the same time to ease this)
Hope this helps
Fabio
2003 ET4 125
Fri Mar 18, 2011 2:17 am quote
Thanks Mate
one more question
What size is the nut on the Variator ( 18mm ?)
Scooter Pimp
Fri Mar 18, 2011 2:31 am quote
For my ET2 it is a 15mm, if I remember correctly.
Fabio
2003 ET4 125
Fri Mar 18, 2011 3:29 am quote
Fabio
Can anyone else verify this for me?
ignoblis
Vespa GTS300ie , Yamaha tricity & T-max 530
Fri Mar 18, 2011 7:40 am quote
125cc leader engine has 18mm floating washer nut ( one time use only )
Scooter Pimp
Fri Mar 18, 2011 9:35 am quote
Thanks Super-fly
I wasn't too sure if the nut size was the same for the ET4 as for the ET2.
ET4 Pre-Leader 125 "Velocipede"
Sat Mar 19, 2011 12:21 am quote
It is a 17mm nut and separate spring washer for the pre-leader ET4.
2003 ET4 125
Sun Mar 20, 2011 7:46 am quote
Guys
Just want to thank you all for your help. The job is done, Rollers are in but did not need to put in a new belt as it looks brand new. The bike feels great.
ignoblis
Sun Mar 20, 2011 9:28 am quote
Aloha and welcome to the forum. Sometimes you can't see the cracking with the naked eye. If it's the original i'd replace it. Better safe than sorry because when a belt breaks it isn't pretty. We just replaced mine a few weeks ago while we had him open. It was 4yrs old but only had 6K. The belt looked alright but who knows. Where in SA are you? I was in J'Berg in Nov. Came in thru Swaziland.
2003 ET4 125
Sun Mar 20, 2011 11:00 am quote
@ Judy
I am in Durban, thanks for the info on the belt, now that I know how to do it I might just get me a new one and replace it. It is not a big job at all.
ignoblis
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   Vespa Wasp Neck Scarves   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.2663s ][ Queries: 23 (0.0334s) ][ Debug on ]
